11. 仿真器¶
仿真器提供了一种方法来测试你的电脑上没有上传到遥控器的 Deviation 固 件。它提供了一个和遥控器相同的虚拟的显示屏,还有一个侧屏显示由键盘虚拟 的摇杆/开关的状态以及信道输出。
从这里下载并解压缩deviation-emu_devoXX-vx.y.z.zip:
其中 XX 是你的 Devention 遥控器型号。XYZ 是 Deviation 版本号。通常情况下, 你应该使用最新的版本。要启动模拟器只需要运行文件夹中的 exe 文件。
仿真器控制如下(以英文 QWERTY 键盘为准):
| 键盘 | 功能 | 遥控器 | ||
| 12 | 8 | 6 | ||
| q/a | Left-Vertical stick (Throttle in mode 2) | X | X | X |
| Q/A | Left-Vertical trim | X | X | X |
| w/s | Left-Horizontal stick (Rudder in mode 2) | X | X | X |
| W/S | Left-Horizontal trim | X | X | X |
| e/d | Right-Vertical stick (Elevator in mode 2) | X | X | X |
| E/D | Right-Vertical trim | X | X | X |
| r/f | Right-Horizontal stick (Aileron in mode 2) | X | X | X |
| R/F | Right-Horizontal trim | X | X | X |
| o/l | AUX2 | X | ||
| p/; | AUX3 | X | ||
| t/g | AUX4 | X | ||
| T/G | Top-Left trim | X | X | |
| y/h | AUX5 | X | ||
| Y/H | Top-Right trim | X | X | |
| u/j | AUX6 | X | ||
| i/k | AUX7 | X | ||
| z | Gear | X | X | X |
| x | Rudder Dual-Rate switch/SW B | X | X | |
| c | Elevator Dual-Rate switch/SW A | X | X | |
| v | Aileron Dual-Rate switch/ | X | X | DR |
| b | Mix 0/1/2 switch | X | X | X |
| n | FMode 0/1/2 switch | X | X | X |
| m | Hold switch | X | ||
| , | Train switch | X | ||
| \ | Power off | X | X | X |
| Left-arrow | Left | X | X | X |
| Right-arrow | Right | X | X | X |
| Up-arrow | Up | X | X | X |
| Down-arrow | Down | X | X | X |
| Enter | Ent | X | X | X |
| Escape | Exit | X | X | X |
