development:docker [2016/05/09 17:49] HappyHarry [Setting up the Docker Container] |
Line 35: | Line 35: | ||
- | <nowiki>''docker create -it -v ~/devo_builds:/release ---name deviation_build deviationtx/deviation-docker''</nowiki> | + | ''<nowiki>docker create -it -v ~/devo_builds:/release --name deviation_build deviationtx/deviation-docker</nowiki>'' |
Line 48: | Line 48: | ||
Line 61: | Line 61: | ||
+ | For instance: | ||
development/docker.txt (171334 views) · Last modified: 2017/04/10 01:08 by mwm
