development
development [2016/04/30 07:33] PhracturedBlue |
development [2016/04/30 08:16] PhracturedBlue |
Line 10: | Line 10: | ||
The legacy instructions on setting up the build environment by hand can be found [[development:setting_up_build_env | here]], but this method is no longer recommended. | The legacy instructions on setting up the build environment by hand can be found [[development:setting_up_build_env | here]], but this method is no longer recommended. | ||
- | Some users have also tried various build approaches. These are generally less well supported, but alternate instructions for building on Windows can be found [[development:building_on_windows | here]], and instructions for building with Eclipse are available [[development:building_with_eclipse | here]]. | + | Some users have also tried various build approaches. These are generally less well supported, but alternate instructions for building on Windows can be found [[development:building_on_windows | here]], and instructions for building with Eclipse are available [[development:building_with_eclipse | here]]. Instructions for building on OSX can be found [[development:building_on_osx | here]] |
Deviation has been designed to be portable to lots of different hardware. While it is easiest to port to STM32 based transmitters, it should be possible to port it to any hardware with a sufficiently capable MCU. The 1st step in supporting a new transmitter is to document its pin connections. We have provided this information for each of the supported transmitters [[hardware | here]] | Deviation has been designed to be portable to lots of different hardware. While it is easiest to port to STM32 based transmitters, it should be possible to port it to any hardware with a sufficiently capable MCU. The 1st step in supporting a new transmitter is to document its pin connections. We have provided this information for each of the supported transmitters [[hardware | here]] |
development.txt (33402 views) ยท Last modified: 2017/01/23 00:22 by FDR
