faq [2016/04/14 21:01]
PhracturedBlue
faq [2017/01/23 00:24] (current)
FDR https
Line 1: Line 1:
 ===== FAQ ===== ===== FAQ =====
 Here you will find answers to frequently asked questions regarding the Deviation firmware Here you will find answers to frequently asked questions regarding the Deviation firmware
-{{INLINETOC:​width18 2-4}}+{{INLINETOC:​3-4}}
 ==== Getting started ==== ==== Getting started ====
-If you are new to deviation firmware, first read this: Getting Started.+If you are new to deviation firmware, first read this: [[get_started_with_deviationtx|Getting Started]].
 ==== I found a bug, now what? ==== ==== I found a bug, now what? ====
-Instructions on reporting bugs can be found here: Reporting bugs+Instructions on reporting bugs can be found here: [[reporting_bugs|Reporting bugs]]
 ==== Will you support my radio? ==== ==== Will you support my radio? ====
-Currently, the Devo6/6S, Devo8/8S, Devo12/12S, Devo10 and Devo7E radios are supported. ​DevoF12E and DevoF7 support has been developed and is undergoing testing. I currently have no plans to support the Devo7. Without USB, and with a segmented display, it is not an appealing platform.+Currently, the Devo6/6S, Devo8/8S, Devo12/12S, Devo10 and Devo7E radios are supported. ​DevoF4, ​DevoF7 ​and DevoF12E ​support has been developed and is undergoing testing. I currently have no plans to support the Devo7. Without USB, and with a segmented display, it is not an appealing platform.
 ==== Do you accept donations? ==== ==== Do you accept donations? ====
Line 22: Line 22:
 ==== I have a <insert brand> receiver, can it be supported? ==== ==== I have a <insert brand> receiver, can it be supported? ====
-The Walkera Devo transmitters use a CYRF6936 transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: CC2500, A7105, NRF74L01. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the MultiModule.+The Walkera Devo transmitters use a [[modulelist/​cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: ​[[modulelist/​cc2500|CC2500]][[modulelist/​a7105|A7105]][[modulelist/​nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/​multimod|MultiModule]]. Alternatively,​ the [[modulelist/​3-in-1 module|3-in-1]] and [[modulelist/​4-in-1 module|4-in-1]] Modules are popular options.
-Deviation with the additional RF modules already supports a lot of protocols, and the number is increasing day after day. You can look at the Supported Models list to seeif your model is supported.+Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see if your model is supported.
 In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip.
Line 37: Line 37:
 ==== HELP! My transmitter won't go into DFU mode ==== ==== HELP! My transmitter won't go into DFU mode ====
-To switch into the DFU mode you need to turn on the TX while holding the '​EXT'​ button pressed. Ensure your TX has fresh batteries, and you are pressing the '​EXT'​ button, which is on the left side of the display.+To switch into the DFU mode you need to turn on the TX while holding the '​EXT'​ button pressed. Ensure your TX has fresh batteries, and you are pressing the '​EXT'​ button, which is on the left side of the display. ​(On the Devo 12/12S, use the trainer switch instead - it's on the right-rear side of the controller.) ​
 If the TX won't go into the DFU mode, or doesn'​t show any sign of life, pull out the batteries for some time (say 15 minutes), and try again. If the TX won't go into the DFU mode, or doesn'​t show any sign of life, pull out the batteries for some time (say 15 minutes), and try again.
 ==== HELP! My transmitter won't go into USB mode ==== ==== HELP! My transmitter won't go into USB mode ====
 To switch into the USB mode you need to turn on the TX while holding the '​ENT'​ button pressed. Ensure your TX has fresh batteries, and you are pressing the '​ENT'​ button, which is on the right side of the display. To switch into the USB mode you need to turn on the TX while holding the '​ENT'​ button pressed. Ensure your TX has fresh batteries, and you are pressing the '​ENT'​ button, which is on the right side of the display.
Line 53: Line 52:
 ==== Can you answer a question about my stock Devo transmitter?​ ==== ==== Can you answer a question about my stock Devo transmitter?​ ====
-A lot of TX experts are here, so probably yes. Ask your question in the "Stock Firmware Help" ​forum. However keep in mind, that the users of this site primarily use deviation on their transmitters,​ and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the RCGroups.+A lot of TX experts are here, so probably yes. Ask your question in the [[https://​www.deviationtx.com/​forum/​stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters,​ and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://​www.rcgroups.com|RCGroups]].
 +==== Are version 4.0.1 models compatible with version 5 firmware? ====
 +There shouldn'​t be any compatibility issues.
faq.1460692874.txt.gz (1304 views) · Last modified: 2016/04/14 21:01 by PhracturedBlue
