| Line 1: | Line 1: | ||
| ===== FAQ ===== | ===== FAQ ===== | ||
| Here you will find answers to frequently asked questions regarding the Deviation firmware | Here you will find answers to frequently asked questions regarding the Deviation firmware | ||
| - | {{INLINETOC:width18 3-4}} | + | {{INLINETOC:3-4}} |
| ==== Getting started ==== | ==== Getting started ==== | ||
| Line 22: | Line 22: | ||
| ==== I have a <insert brand> receiver, can it be supported? ==== | ==== I have a <insert brand> receiver, can it be supported? ==== | ||
| - | The Walkera Devo transmitters use a [[modulelist/cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. | + | The Walkera Devo transmitters use a [[modulelist/cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/cc2500|CC2500]], [[modulelist/a7105|A7105]], [[modulelist/nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/multimod|MultiModule]]. Alternatively, the [[modulelist/3-in-1 module|3-in-1]] and [[modulelist/4-in-1 module|4-in-1]] Modules are popular options. |
| - | Deviation with the additional RF modules already supports a lot of protocols, and the number is increasing day after day. You can look at the [[https://docs.google.com/spreadsheet/ccc?key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&usp=sharing|Supported Models]] list to see, if your model is supported. | + | Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]], and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see if your model is supported. |
| In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. | In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. | ||
| Line 37: | Line 37: | ||
| ==== HELP! My transmitter won't go into DFU mode ==== | ==== HELP! My transmitter won't go into DFU mode ==== | ||
| - | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. | + | To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'EXT' button, which is on the left side of the display. (On the Devo 12/12S, use the trainer switch instead - it's on the right-rear side of the controller.) |
| If the TX won't go into the DFU mode, or doesn't show any sign of life, pull out the batteries for some time (say 15 minutes), and try again. | If the TX won't go into the DFU mode, or doesn't show any sign of life, pull out the batteries for some time (say 15 minutes), and try again. | ||
| ==== HELP! My transmitter won't go into USB mode ==== | ==== HELP! My transmitter won't go into USB mode ==== | ||
| To switch into the USB mode you need to turn on the TX while holding the 'ENT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'ENT' button, which is on the right side of the display. | To switch into the USB mode you need to turn on the TX while holding the 'ENT' button pressed. Ensure your TX has fresh batteries, and you are pressing the 'ENT' button, which is on the right side of the display. | ||
| Line 53: | Line 52: | ||
| ==== Can you answer a question about my stock Devo transmitter? ==== | ==== Can you answer a question about my stock Devo transmitter? ==== | ||
| - | A lot of TX experts are here, so probably yes. Ask your question in the "Stock Firmware Help" forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. | + | A lot of TX experts are here, so probably yes. Ask your question in the [[https://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. |
| + | ==== Are version 4.0.1 models compatible with version 5 firmware? ==== | ||
| + | There shouldn't be any compatibility issues. | ||
faq.1460730867.txt.gz (1284 views) · Last modified: 2016/04/15 07:34 by FDR
