faq [2016/11/25 15:21]
Arnold
faq [2017/01/23 00:24] (current)
FDR https
Line 22: Line 22:
 ==== I have a <insert brand> receiver, can it be supported? ==== ==== I have a <insert brand> receiver, can it be supported? ====
-The Walkera Devo transmitters use a [[modulelist/​cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/​cc2500|CC2500]],​ [[modulelist/​a7105|A7105]],​ [[modulelist/​nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/​multimod|MultiModule]]. Alternatively,​ the 3-in-1 and 4-in-1 Modules are popular options.+The Walkera Devo transmitters use a [[modulelist/​cyrf6936|CYRF6936]] transceiver chip. In theory any receiver using this chip could be compatible with Deviation. It would, of course, require analyzing the protocol to make it work. There are 3 other common transceiver chips in the 2.4GHz RC domain: [[modulelist/​cc2500|CC2500]],​ [[modulelist/​a7105|A7105]],​ [[modulelist/​nrf24l01|NRF74L01]]. Modules for each of these can be purchased for ~$15 each from China. Currently Deviation supports all of them, but only two additional RF modules can be installed into a Tx without the help of some additional DIY hardware called the [[modulelist/​multimod|MultiModule]]. Alternatively,​ the [[modulelist/​3-in-1 ​module|3-in-1]] ​and [[modulelist/​4-in-1 module|4-in-1]] Modules are popular options.
-Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]],​ and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to seeif your model is supported.+Deviation with the additional RF modules already supports a [[supported_protocols|lot of protocols]],​ and the number is increasing day after day. You can look at the [[supported_models|Supported Models]] list to see if your model is supported.
 In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip. In order to support a new protocol, we need to know what transceiver chipset is used in the particular model. If you are not sure, post detailed pictures of the TX and/or RX board. If the chipset is supported, we need captures of the data flow between the microcontroller and the transceiver chip.
Line 52: Line 52:
 ==== Can you answer a question about my stock Devo transmitter?​ ==== ==== Can you answer a question about my stock Devo transmitter?​ ====
-A lot of TX experts are here, so probably yes. Ask your question in the [[http://​www.deviationtx.com/​forum/​stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters,​ and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://​www.rcgroups.com|RCGroups]].+A lot of TX experts are here, so probably yes. Ask your question in the [[https://​www.deviationtx.com/​forum/​stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters,​ and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://​www.rcgroups.com|RCGroups]].
 ==== Are version 4.0.1 models compatible with version 5 firmware? ==== ==== Are version 4.0.1 models compatible with version 5 firmware? ====
 There shouldn'​t be any compatibility issues. There shouldn'​t be any compatibility issues.
faq.1480116092.txt.gz (1281 views) ยท Last modified: 2016/11/25 15:21 by Arnold
