hardware:jumper_t12
hardware:jumper_t12 [2019/01/26 05:35] PhracturedBlue |
hardware:jumper_t12 [2019/02/13 20:50] PhracturedBlue |
Line 12: | Line 13: | ||
- | |0 |Stick RV | | + | |0 (ADC_IN_0) |Stick RV | |
- | |1 |Stick RH | | + | |1 (ADC_IN_1) |Stick RH | |
- | |2 |Stick LV | | + | |2 (ADC_IN_2) |Stick LV | |
- | |3 |Stick LH | | + | |3 (ADC_IN_3) |Stick LH | |
- | |6 |POT1 | | + | |6 (ADC_IN_6) |POT1 | |
Line 31: | Line 32: | ||
- | |0 |POT2 | | + | |0 (ADC_IN_8) |POT2 | |
|3 |??? | | |3 |??? | | ||
Line 41: | Line 42: | ||
Line 50: | Line 51: | ||
- | |0 |Voltage detect | | + | |0 (ADC_IN_10) |Voltage detect | |
- | |2 |Buttom 'Trim RVU' | | + | |2 |Button 'Trim RVU' | |
- | |3 |Buttom 'Trim RVD' | | + | |3 |Button 'Trim RVD' | |
Line 69: | Line 70: | ||
Line 80: | Line 81: | ||
|10 |??? | | |10 |??? | | ||
- | |11 |Switch: C_11 | | + | |11 |Switch: C_L | |
|12 |LCD RST | | |12 |LCD RST | | ||
=== GPIOE === | === GPIOE === |
hardware/jumper_t12.txt (71275 views) · Last modified: 2019/04/26 15:22 by goebish
