User Tools
Site Tools
model_config:super_cp
Super CP
Finished my config for the Super CP and said I'd share it in case it's useful to someone.
I tried to keep it close to the standard setup in the heli's manual.
Throttle hold is controlled by RUDD D/R, cuts throttle but does not affect pitch.
There are 3 gyro settings, which are controlled by the Mix switch.
Mix0 - 75%
Mix1 - 50%
Mix2 - 40%
There are 3 flight modes, controlled by the FMOD switch.
FMOD 0 = Standard flight
70% rates on aileron and elevator channels
-20 to +50 pitch curve
FMOD 1 = Stunt mode 1
-50 to +50 pitch curve
V throttle curve - 100%, 75%, 100%
FMOD 2 = Stunt mode 2
100% rates on aileron and elevator channels
AILE D/R will give 100% throttle output, regardless of the position of FMOD.
model7
model_config/super_cp.txt (155399 views) · Last modified: 2013/03/11 19:16 by coreire
