User Tools
Site Tools
model_config:v500d01_devo
V500D01 DEVO
This is for the V500D01 with 2702v-D gyro RX.
This is from a DEVO 12
You may need to edit the switches.
(This is a good test to see how it translates to other TX's)
Flight mode switch is for both throttle and pitch curves.
F0 - Normal
F1 - Full pitch, V throttle curve
F2 - Full pitch, almost straight throttle line
AIL and ELE rates are on the MIX switch, 60,80,100 rates. 10% expo on all, Walkera manual says 45%… edit as you like.
RUD rates 75, 100 on RUD D/R switch.
Throttle hold on HOLD switch.
Gyro on Gear switch, +65%, -65% with Gyro TRIM on the Left trim.
Also note I have a fixed ID, you may want to clear it.
model15
model_config/v500d01_devo.txt (11114 views) · Last modified: 2013/03/20 20:20 by Hexperience
