playground:playground
playground:playground [2017/10/15 18:18] MikeNH [Sandbox page for testing formatting, etc] |
playground:playground [2018/05/02 23:39] |
- | ====== 3-in-1 Module ====== | ||
- | Adding this module to your Devo supplies the CC2500, A7105, and NRF24L01 RF modules in one package. Each module uses the one common antenna connection that is provided on the package. | ||
- | 3 - Click Edit in either the Tutorials or How-Tos section. \\ | ||
- | 4 - |
playground/playground.txt (48973 views) · Last modified: 2018/05/02 23:39 (external edit)
