rf_module_installation:devo7e
rf_module_installation:devo7e [2016/04/15 09:08] FDR [Module Installation] |
rf_module_installation:devo7e [2016/04/15 12:01] (current) FDR [Installing a module into a Devo7e Transmitter] |
| Line 1: | Line 1: | ||
| ===== Installing a module into a Devo7e Transmitter ===== | ===== Installing a module into a Devo7e Transmitter ===== | ||
| ==== Prepare Devo Transmitter ==== | ==== Prepare Devo Transmitter ==== | ||
| First Remove the screws from the back of the Devo7e Transmitter | First Remove the screws from the back of the Devo7e Transmitter | ||
| Line 15: | Line 15: | ||
| ==== Module Installation ==== | ==== Module Installation ==== | ||
| - | Follow the table and images on the [[/modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo7e: | + | Follow the table and images on the [[:modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo7e: |
| Pins MISO, MOSI, and SCK connect to the CYRF6936 Module. | Pins MISO, MOSI, and SCK connect to the CYRF6936 Module. | ||
rf_module_installation/devo7e.1460736504.txt.gz (3974 views) ยท Last modified: 2016/04/15 09:08 by FDR
