transmitter:devo7e
transmitter:devo7e [2016/05/08 09:01] silpstream Formatting changes |
transmitter:devo7e [2016/05/08 13:18] silpstream fix links |
Line 25: | Line 25: | ||
=== Installing DeviationTx === | === Installing DeviationTx === | ||
+ | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part2 - deviationTX installation]] by SeBy DocKy | ||
=== Modifications === | === Modifications === | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Walkera Devo 7E TransmitterDeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part7 - nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part8 - CC2500 mod]] by SeBy DocKy | ||
Line 49: | Line 65: | ||
- | ---- | + | == USB Charge Mod == |
- | === Other Devo 7E Information === | + | === Other Devo 7E Resources === |
- | + | *[[http://www.drone-maniac.com/diy-devo-7e-tutorials/|DIY: DEVO 7E TUTORIALS]] | |
- | ---- | + | *[[http://www.hacksmods.com/tag/devo7e/|Devo 7E on hacksmods.com]] |
=== Hardware Information === | === Hardware Information === | ||
- | *[[hardware:devo7e|Devo 7E Hardware Connections]] | + | *[[hardware:devo7e|Devo 7E Hardware & Connections]] |
transmitter/devo7e.txt (4360 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
