transmitter:devo7e
transmitter:devo7e [2016/05/08 09:01] silpstream Formatting changes |
transmitter:devo7e [2016/05/08 22:14] silpstream fix links |
Line 24: | Line 24: | ||
+ | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
- | === Modifications === | + | If that's not enough, the tutorials below should get you going. |
- | Due to its' popularity, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | + | *[[https://youtu.be/cj36KytnsQo|HowTo: Install DEVIATION on a Walkera Devo 7e]] by RCFanBlog |
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part2 - deviationTX installation]] by SeBy DocKy | ||
+ | Due to its' popularity and price, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Walkera Devo 7E TransmitterDeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part7 - nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part8 - CC2500 mod]] by SeBy DocKy | ||
+ | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?) within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] on our fourm | ||
Line 48: | Line 73: | ||
+ | == USB Charge Mod == | ||
- | === Other Devo 7E Information === | + | ==== Other Devo 7E Resources ==== |
- | === Hardware Information === | + | ==== Hardware Information ==== |
- | *[[hardware:devo7e|Devo 7E Hardware Connections]] | + | *[[hardware:devo7e|Devo 7E Hardware & Connections]] |
transmitter/devo7e.txt (86578 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
