transmitter:devo7e
transmitter:devo7e [2016/05/08 09:01] silpstream Formatting changes |
transmitter:devo7e [2019/02/22 15:39] (current) PhracturedBlue |
Line 24: | Line 26: | ||
+ | Start by reading the Devo 7E [[https://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
- | === Modifications === | + | If that's not enough, the tutorials below should get you going. |
- | Due to its' popularity, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | + | *[[https://youtu.be/cj36KytnsQo|HowTo: Install DEVIATION on a Walkera Devo 7e]] by RCFanBlog |
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|DeviationTX Installation]] by SeBy DocKy | ||
+ | Due to its' popularity and price, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | ||
+ | == Disassembly == | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Devo 7E DeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | ||
- | ---- | + | == USB Charge Mod == |
- | === Other Devo 7E Information === | + | == 3D Printable Parts == |
- | === Hardware Information === | + | ==== Other Devo 7E Resources ==== |
- | *[[hardware:devo7e|Devo 7E Hardware Connections]] | + | *[[http://www.rcgroups.com/forums/showthread.php?t=1693112|New Devo 7E Radio from Walkera]] on rcgroups.com |
transmitter/devo7e.1462723291.txt.gz (85328 views) · Last modified: 2016/05/08 09:01 by silpstream
