voiceoutput
voiceoutput [2018/01/31 06:12] Moeder devo7e info update |
Line 71: | Line 71: | ||
Line 78: | Line 78: | ||
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
Line 92: | Line 107: | ||
Line 134: | Line 149: | ||
voiceoutput.1517407976.txt.gz (56661 views) · Last modified: 2018/01/31 06:12 by Moeder
