voiceoutput
| Line 107: | Line 107: | ||
| == Voice Files: == | == Voice Files: == | ||
| - | Deviation software nightly builds do not include the voice files, and the user must also download a basic set of voice alerts. The files are currently available in the [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] folder under [[https://www.deviationtx.com/downloads-new/category/705-moeder-voice-alerts|Test Builds/[Moeder]voice_alerts]] and are available in English, French and German. An expanded set of English voice alerts is also available. Each zip file includes the required MP3 Folder and a voice.ini file catalog. | + | Deviation software nightly builds do include the voice features since April 2017, but the user must also download a set of voice alerts. The files are currently available in the [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] folder under [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] and are available in English, French and German. Each zip file includes the required MP3 Folder and a voice.ini file catalog. |
| - | You can also use the [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]] service to create your own custom voice sets. This service will continue to evolve in the next weeks. | + | You can also use the [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]] service to create your own custom voice sets. This service will continue to evolve. |
| The files for the DFPlayer are saved using MP3 format and are contained in the //\MP3// folder on the MicroSD card. The MicroSD must be set up with the //\MP3// folder and all the voice alert files must be in that folder. No other files or folders need to be on the card, so the card can be a small as 64MB (the actual disk storage for the largest file set is under 2MB). | The files for the DFPlayer are saved using MP3 format and are contained in the //\MP3// folder on the MicroSD card. The MicroSD must be set up with the //\MP3// folder and all the voice alert files must be in that folder. No other files or folders need to be on the card, so the card can be a small as 64MB (the actual disk storage for the largest file set is under 2MB). | ||
| Line 149: | Line 149: | ||
| ==== Setting up the emulator for voice alerts ==== | ==== Setting up the emulator for voice alerts ==== | ||
| - | Download and unzip the emulator package for your transmitter. Then make these changes: | + | Download and unzip the emulator package for your transmitter. |
| - | - Be sure that the file //mp3123.exe// is in main folder with emulator exe package; it is now included in the nightly emulator builds. | + | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. |
| - | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/705-moeder-voice-alerts|Test Builds/[Moeder]voice_alerts]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. | + | |
| - Update the file system as you would update the TX file system: | - Update the file system as you would update the TX file system: | ||
| * Make appropriate changes to the //hardware.ini// | * Make appropriate changes to the //hardware.ini// | ||
| * Copy the //voice.ini// to the //\media// folder | * Copy the //voice.ini// to the //\media// folder | ||
| * Edit each //model.ini// to enable sounds or use the voice configuration menu (except devo7e, see above). | * Edit each //model.ini// to enable sounds or use the voice configuration menu (except devo7e, see above). | ||
voiceoutput.1525362500.txt.gz (157339 views) · Last modified: 2018/05/03 08:48 by Moeder
