voiceoutput
voiceoutput [2017/05/17 18:46] Deal57 [Wiring diagram] |
Line 62: | Line 67: | ||
The serial signal is not available at the trainer port, but rather on a neat pin header labeled "TX/RX" on the Main board - perfect for internal installation of a DFPlayer module. | The serial signal is not available at the trainer port, but rather on a neat pin header labeled "TX/RX" on the Main board - perfect for internal installation of a DFPlayer module. | ||
+ | === Powering the Voice Alert Module === | ||
+ | The DFPlayer module can be powered by 3.3v to 5v, with 4.2v recommended. A fully charged 1S, 3.6v lipo provides adequate voltage. At full volume the board may use 70ma+ momentarily, and in standby it is rated at 20ma. In testing, a 200mah 3.6 lipo lasted over two weeks of regular use (15-20 min/day). | ||
+ | Although not required, the Pololu S7V8A adjustable stepup/stepdown regulator can ensure that the voltage is consistent and stable. It can be wired to a 3.3 or 5v switched source near the power circuits (the location of which will vary by TX) to avoid affecting other electrical needs of the transmitter. The S7V8A can also be wired directly to the battery-in port, provided that the -SHUTDOWN is connected (varies by TX). | ||
+ | Here are some example power locations for transmitters. The forums may provide additional information as more pilots adopt the voice alerts feature. | ||
+ | * In the Devo 12e, connect to the Vdd and ground on the Debug port. This may be a good power source for the Devo 10 as well. | ||
+ | * In the Devo 6s, the Vdd and ground on the Debug port are convenient, and can be used if there are not other add-ons in use (such as the Multiprotocol board or other transmitter modules). | ||
+ | * In the Devo 7e power is a challenge: search the forum for more details. [[https://www.deviationtx.com/forum/6-general-discussions/6246-devo-7e-voltage-supply?start=20#53017|This excellent post]] is a good place to start. | ||
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
+ | === Install and Configure the voice alert sound files === | ||
+ | == Using the DFPlayer MicroSD card == | ||
+ | The DFPlayer uses a small MicroSD card with the standard USB Storage Device file system. Use a MicroSD card with a capacity of at least 64MB -- yes, that's MEGABYTE, not GIGABYTE, so pretty much any old MicroSD card will be sufficient. The MicroSD card can be formatted and accessed from a PC or Mac. Prior to using in the Voice Alerts system, the MicroSD card must be formatted and loaded with the correct voice alert files. | ||
+ | == USB Format and Access: == | ||
+ | The DFPlayer MicroSD card can be formatted on your PC or MAC, after which files can be dragged-n-dropped as needed. If the card is formatted and inserted into the DFPlayer, the card is also accessible from your PC or Mac by connecting to the DFPlayer USB port. Either way, the card appears as a USB storage device on your PC or Mac. | ||
+ | {{:hardware:voice:usb_drive_root_folder.png?|}} | ||
+ | == Voice Files: == | ||
+ | Deviation software nightly builds do include the voice features since April 2017, but the user must also download a set of voice alerts. The files are currently available in the [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] folder under [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] and are available in English, French and German. Each zip file includes the required MP3 Folder and a voice.ini file catalog. | ||
+ | The files for the DFPlayer are saved using MP3 format and are contained in the //\MP3// folder on the MicroSD card. The MicroSD must be set up with the //\MP3// folder and all the voice alert files must be in that folder. No other files or folders need to be on the card, so the card can be a small as 64MB (the actual disk storage for the largest file set is under 2MB). | ||
+ | Each file is named to correspond to [[https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#FAQ|DFPlayer MP3 file name convention]], which requires a 4-digit number as the first four characters of the filename, and a filetype of MP3 (ex: //0000.MP3// or //0000Welcometodeviation.MP3//). MAC users should be aware of special file handling requirements as detailed on the DFRobot page. | ||
+ | {{:hardware:voice:usb_drive_mp3_folder.png?|}} | ||
+ | === Deviation transmitter software changes === | ||
+ | Once the voice alerts hardware is available and files are on the player, there are three changes required to the transmitter software. | ||
+ | == Update hardware.ini file == | ||
+ | The first change is to update the //hardware.ini// file to include a line(s) defining the voice player hardware. For the DFPlayer, use "voice=dfplayer" and remove the semicolon from the first character of the line. Use "voice=audiofx" for the AudioFX players. If your audio device is wired to the UART5 port (only available on the Devo7e-256), you must also add "voice-uart 5=1" and remove the semicolon. | ||
The used audio player (and possibly the special wiring for Devo7e-256) has to be enabled in //hardware.ini// located in the root directory of your transmitter: | The used audio player (and possibly the special wiring for Devo7e-256) has to be enabled in //hardware.ini// located in the root directory of your transmitter: | ||
Line 68: | Line 129: | ||
;voice= | ;voice= | ||
;voice-uart5=1 | ;voice-uart5=1 | ||
</code> | </code> | ||
+ | == Deviation Voice Media catalog file voice.ini == | ||
+ | The voice alert files are cataloged in a file called //voice.ini// that must be copied to the deviation \media (\mymedia on Devo12(S)) folder on the transmitter. The //voice.ini// file contains lines that correspond to each voice alert file (ex: "0=Welcome to deviation,1617") that map the MP3 file name and duration for Deviation. Each set of deviation voice alert files must have a //voice.ini// file to match. | ||
+ | {{:hardware:voice:voice_ini_file_example.png?|}} | ||
+ | == Update Model.ini files == | ||
+ | The third change to the deviation transmitter is to configure the sounds in each model by using the voice config menu of each model (except for devo7e) or by directly editing the model.ini. | ||
+ | Download and unzip the emulator package for your transmitter. | ||
+ | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. | ||
+ | - Update the file system as you would update the TX file system: | ||
+ | * Make appropriate changes to the //hardware.ini// | ||
+ | * Copy the //voice.ini// to the //\media// folder | ||
+ | * Edit each //model.ini// to enable sounds or use the voice configuration menu (except devo7e, see above). |
voiceoutput.1495072012.txt.gz (52943 views) ยท Last modified: 2017/05/17 18:46 by Deal57
