voiceoutput
voiceoutput [2017/05/25 19:06] Deal57 [Software Configuration] formatting updates |
Line 66: | Line 71: | ||
* In the Devo 12e, connect to the Vdd and ground on the Debug port. This may be a good power source for the Devo 10 as well. | * In the Devo 12e, connect to the Vdd and ground on the Debug port. This may be a good power source for the Devo 10 as well. | ||
* In the Devo 6s, the Vdd and ground on the Debug port are convenient, and can be used if there are not other add-ons in use (such as the Multiprotocol board or other transmitter modules). | * In the Devo 6s, the Vdd and ground on the Debug port are convenient, and can be used if there are not other add-ons in use (such as the Multiprotocol board or other transmitter modules). | ||
- | * In the Devo 7e power is a challenge: search the forum for more details. | + | * In the Devo 7e power is a challenge: search the forum for more details. [[https://www.deviationtx.com/forum/6-general-discussions/6246-devo-7e-voltage-supply?start=20#53017|This excellent post]] is a good place to start. |
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
Line 87: | Line 107: | ||
Line 107: | Line 129: | ||
;voice= | ;voice= | ||
Line 115: | Line 138: | ||
== Deviation Voice Media catalog file voice.ini == | == Deviation Voice Media catalog file voice.ini == | ||
- | The voice alert files are cataloged in a file called //voice.ini// that must be copied to the deviation \media folder on the transmitter. The //voice.ini// file contains lines that correspond to each voice alert file (ex: "0=Welcome to deviation,1617") that map the MP3 file name and duration for Deviation. Each set of deviation voice alert files must have a //voice.ini// file to match. | + | The voice alert files are cataloged in a file called //voice.ini// that must be copied to the deviation \media (\mymedia on Devo12(S)) folder on the transmitter. The //voice.ini// file contains lines that correspond to each voice alert file (ex: "0=Welcome to deviation,1617") that map the MP3 file name and duration for Deviation. Each set of deviation voice alert files must have a //voice.ini// file to match. |
{{:hardware:voice:voice_ini_file_example.png?|}} | {{:hardware:voice:voice_ini_file_example.png?|}} | ||
- | - The file //MP3123.exe// is in main folder with emulator exe package and included in the nightly emulator builds. | + | Download and unzip the emulator package for your transmitter. |
- | - Download the //\mp3// folder and files and place the //\mp3// Folder in main folder with exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/705-moeder-voice-alerts|Test Builds/[Moeder]voice_alerts]] | + | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/1010-moeder-voice-packs|Test Builds/[Moeder]voice_packs]] or in the voice packs created by [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]]. |
- | * Make appropriate changes to the //hardware.ini// | + | * Make appropriate changes to the //hardware.ini// |
- | * Copy the //voice.ini// to the //\media// folder | + | * Copy the //voice.ini// to the //\media// folder |
voiceoutput.1495764384.txt.gz (52928 views) · Last modified: 2017/05/25 19:06 by Deal57
