voiceoutput
voiceoutput [2018/01/31 06:01] Moeder Add link to voice packer |
Line 2: | Line 2: | ||
- | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms, however Devo 7e users have limited editing functionality. At the current time, the Devo 7e can play the voice alerts, but 1) the nightly build doesn't include the functionality, so you may need to request a custom build and 2) the voice configuration editor menu is not available due to space limitations. The [[voiceoutput#Setting up the emulator for voice alerts|7e Emulator]] has these features so that voice configurations and models can be edited. Models can also be edited manually on a PC. | + | Voice alerts are available by installing the appropriate hardware and the latest nightly [[http://deviationtx/downloads-new|Deviationtx.com Downloads]] for your TX. The voice feature runs on all Deviation platforms except for Devo7e due to memory limitations. |
Line 69: | Line 71: | ||
Line 76: | Line 78: | ||
+ | <code ini> | ||
+ | voice=dfplayer | ||
+ | voice-uart5=1 | ||
+ | </code> | ||
Line 90: | Line 107: | ||
- | You can also use the [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviatio Voicepacker]] service to create your own custom voice sets. This service will continue to evolve in the next weeks. | + | You can also use the [[https://moeder.pythonanywhere.com/voicepacker/default/index|Deviation Voicepacker]] service to create your own custom voice sets. This service will continue to evolve. |
Line 125: | Line 142: | ||
== Adjust transmitter volume == | == Adjust transmitter volume == | ||
Line 132: | Line 149: | ||
- | - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe. The //\mp3// folder is included in the voice alerts zip file from [[https://www.deviationtx.com/downloads-new/category/705-moeder-voice-alerts|Test Builds/[Moeder]voice_alerts]] | + | |
voiceoutput.1517407292.txt.gz (52983 views) · Last modified: 2018/01/31 06:01 by Moeder
