- [HELP]Devo 8s Don't work with WK2401 protocol
- CAPETA
- Topic Author
www.deviationtx.com/manuals/html-devo8-e...html#protocol-wk2801
- -=Hubi-Dirk=-
first I had a Devo 8s and flew all my Walkers helicopters with it until I switched to a 12s some time ago. Both TXs are and were with Deviation 5.0 (different Nightlys).
I fly the Walkera helicopters 4#3B (protocol WK2401), 4G3 (WK2601) and 4G6 (WK2801) without any problems.
Which Walkera helicopter model do you use?
- CAPETA
- Topic Author
When i set Full Throtle quicly, the tail motor starts to work, but a few secs later it stops and only the main motor still working, however when i gradually pull the throtle up, the tail motor don't spin even a bit. When a change from Advanced Mix Gui to Standard Mix Gui, the tail motor starts to work full-throtle even with the throtle stick at 0% until the bind process ends, after that the same problem starts again.
PS: When i turn my 8s on with Standard mix set, the tail motor starts to works at full throtle too
- -=Hubi-Dirk=-
I programmed the 4G3 with the RX2605 using the WK2801 protocol. This is possible and works well for me.
The model.ini and the bmp-file for the 4G3 is attached, try them out. For safety reasons please remove the main rotor blades
- CAPETA
- Topic Author
- CAPETA
- Topic Author
PS: if you asking about the second one, nothing broke. Everything is fine
- -=Hubi-Dirk=-
to the videos: Delete the Fixed ID and try it without, the ID is not necessary
Attached my config for 4#3B, protocol WK2401.
There is a model.ini for the CB180 here in the forum. Try this one too:
deviationtx.com/forum/model-configs/2105...2-config-files#13635
- CAPETA
- Topic Author
- -=Hubi-Dirk=-
Another hint: In the first video I saw that the trim for the gas channel is in the middle. Please adjust the trim to the bottom and the scale for the Thr back to 100%. Then try if the rear engine starts and stays running.
- Birdman
Have a read of this thread.
www.deviationtx.com/forum/model-configs/...cb180q2-config-files
- Birdman
- Birdman
- Birdman
mixermode=Advanced
[radio]
protocol=WK2401
num_channels=4
fixed_id=123456
tx_power=10mW
[channel1]
reverse=1
template=simple
[mixer]
src=ELE
dest=Ch1
curvetype=expo
points=-40,-40
[channel2]
reverse=1
template=simple
[mixer]
src=AIL
dest=Ch2
curvetype=expo
points=-40,-40
[channel3]
template=complex
[mixer]
src=THR
dest=Ch3
[mixer]
src=THR
dest=Ch3
switch=RUD DR1
scalar=-100
usetrim=0
curvetype=fixed
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-73
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=THR
resetsrc=GEAR1
time=480
[timer2]
src=THR
resetsrc=GEAR1
[safety]
Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Timer1
box2=Timer2
box7=Ch3
box8=Ch4
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=RUD DR
tglico1=0,2,0
toggle2=GEAR
tglico2=0,5,0
toggle3=MIX
tglico3=4,0,6
toggle4=FMODE
tglico4=0,3,1
quickpage1=Model setup
- Birdman
- CAPETA
- Topic Author
- Birdman
Maybe try a smaller and larger scale on RUD channel. 80 or 90 and 110 or 120.
I would think that if it binds and everything else works so should tail motor with right settings.
- Birdman
- CAPETA
- Topic Author
- Birdman
edit: Should probably be 100, as should all channels.
- Home
