Walkera 4F180 and CB180Q2 Config Files
21 Aug 2013 06:17 #13062 by tengarang
Walkera 4F180 and CB180Q2 Config Files was created by tengarang
Hi All,
I am wondering if anyone has done any work on the Walkera 4F180 and CB180Q2.
Both are fixed pitched and uses the WK-2403 control which is embeded with optimized presets.
Today with the version 3.0.0 using Devo 8S I was attempting to work on the 4F180 by "tweaking" the 2401 protocol. Or could one start with the 2801 protocol and go from there, but from what I could remember, the 4F180 (flybarless -3 axis gyro) which is a 4 channel fixed pitched helicopter like the CB180Q2 (flybar) would not bind to the 2801 Pro TX....Anyway, my knowledge in this arena is limited. I would like some help with either setting up both helicopters mentioned in here using either the 2401 protocol or the 2801 protocol.
Any similar setups or ideas are highly appreciated.
Thanks Everyone
  • rbe2012
  • rbe2012's Avatar
21 Aug 2013 09:41 #13078 by rbe2012
Replied by rbe2012 on topic Walkera 4F180 and CB180Q2 Config Files
As far as I know you will have to select 2401/2601 protocol in WK2801 also.
So for deviation it is ok to use WK2401 as protocol - I have tested the CB180 some time ago with this.
21 Aug 2013 14:40 #13109 by HeliIntervention
Replied by HeliIntervention on topic Walkera 4F180 and CB180Q2 Config Files
by default on my devo 10 in any of the 28** modes its in a ID bind configuration. Delete the ID and it will be set to none then bind as normal.
21 Aug 2013 17:39 #13127 by tengarang
Replied by tengarang on topic Walkera 4F180 and CB180Q2 Config Files
Thanks guys, Ill try both and report back
07 Sep 2013 18:42 #13634 by DragonFly
Replied by DragonFly on topic Walkera 4F180 and CB180Q2 Config Files
work with my cb180Q protocol wk2401 ;)
File Attachment:
File Name: model3.ini
File Size:4 KB
07 Sep 2013 18:54 #13635 by DragonFly
Oups! Sorry the last one config file is bad, reverse ch nok,
this one is the good.
File Attachment:
File Name: model3_2013-09-07.ini
File Size:4 KB
Time to create page: 0.106 seconds
