Deviation v5.0.0 build with latest protocols
06 Feb 2017 05:42 - 08 Feb 2017 04:52 #58801 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
Revert "Increase maximum number of model files from 100 to 255, from hexfet"
Transmitter reboot with any number of models more than ~110-120, if last model is selected. If number of models is about 150-255, transmitter reboot with any attempt to select new model. Will be useful if anybody test it with Nightly Builds.
(06.02.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Files deleted, see below...
Last edit: 08 Feb 2017 04:52 by vlad_vy.
06 Feb 2017 07:25 - 06 Feb 2017 08:22 #58802 by vlad_vy
Tested it with last Nightly Build (2017-02-05), it has the same problem, transmitter reboot with large number of models. (Devo8)
Last edit: 06 Feb 2017 08:22 by vlad_vy.
06 Feb 2017 08:35 #58805 by proteus
Replied by proteus on topic Deviation v5.0.0 build with latest protocols
My little English is a can limit to explain but I will try.
On version 4.X and 5.0, to set up a model, simply click on the icon of the model and then move from page to page with the arrow at top/right of the screen.
Since NB versions, with the touch, not only must you leave the model to enter the screen that groups the configurations, but it is necessary to stand out of each configuration page to go back to another page.
I think I summarized the feeling of those who have a devo8 or 12 (if an anglophone can confirm my sayings)
06 Feb 2017 11:25 #58812 by FDR
I see, thanks!
I don't know how often someone configures the whole model at once going through all the pages without closing them, because this is not how I do it.
First I configure the model setup to have a name and a protocol set and bound.
I configure the mixers after that, but the mixer part is altered often anyway. (That's why it was the starting screen, and not the model setup page, which you need to setup first, but only once.)
Usually later in time, sometimes even after a few flights I set up a timer or refine the telemetry warnings.
Finally I customize the main screen to my likings.
I rarely touch the trims, and never the flight log, but I need to scroll through them every time I want to get to a specific page, and I find it just as annoying as navigating back to the menu to get to an other page.
It wasn't that painful in the beginning, when we had only 4 pages, but now we have 7...
08 Feb 2017 04:54 - 12 Feb 2017 15:36 #58897 by vlad_vy
*Increase maximum number of model files from 100 to 200, from FDR
(08.02.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 12 Feb 2017 15:36 by vlad_vy.
12 Feb 2017 15:38 - 26 Feb 2017 15:30 #59091 by vlad_vy
*Remove unused "fontColor" from the button calls, from FDR
*Add LQI and LRSSI telemetry values to Frsky and FrskyX, from hexfet
(12.02.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 26 Feb 2017 15:30 by vlad_vy.
26 Feb 2017 15:32 - 21 Mar 2017 08:41 #59652 by vlad_vy
* Add GW008 protocol, from goebish
(26.02.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 21 Mar 2017 08:41 by vlad_vy.
21 Mar 2017 08:42 - 24 Mar 2017 07:12 #60470 by vlad_vy
* Add Fayee FY805 format to MT99xx protocol, from goebish
(21.03.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 24 Mar 2017 07:12 by vlad_vy.
24 Mar 2017 07:11 - 08 May 2017 05:48 #60667 by vlad_vy
* Add EAchine DM002 protocol, from goebish
Protocol name: DM002
Mapping:
Channel 5: Leds
Channel 6: Flip
Channel 7: video record (feature is in the stock Tx, however the DM002 does not have a recording camera)
Channel 8: camera snapshot (same)
Channel 9: Headless
Channel 10: RTH
There are only 2 hardcoded transmitter IDs, choosing an even or odd transmitter ID in deviation switch between them.
Forums thread: www.deviationtx.com/forum/protocol-devel...ol-contains-captures
(24.03.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 08 May 2017 05:48 by vlad_vy.
02 May 2017 00:34 - 02 May 2017 03:38 #61917 by Whatsinaname
Replied by Whatsinaname on topic Deviation v5.0.0 build with latest protocols
Hello vlad_vy,
I was wondering if there are any changes in the dsm2/dsmx protocols you are posting here.
I ask because when I installed the 4in1 module into my 7e and installed the latest deviation nightly I started having some strange range issues (still testing but so far the good results are pointing toward software and not hardware).
When I reverted back to the 5.0 stable version and then uploaded your dfu and protocol folder I found my dsm2/dsmx range issues have seem to have been resolved (again still testing).
Is there any difference in the protocol files for dsm2/dsmx you are using compared to the nightlys?
Many thanks as your files have helped my devo 7e to gain another step in becoming my favorite tx. AFHDS2A works flawlessly with FSA8S receiver by the way.
EDIT: Just put three batteries through my 250 frames (1 on lemonrx dsmx and 2 on redcon dsmx) and had zero brownouts. When I was on the nightly (2017 Apr) I couldn't get beyond 10 ft on 150mW tx power. I had checked all hardware before reverting the software. So I want to go on a limb here and say that the dsm2/dsmx protocols from the 24Mar2017 devo7e zip file is a solid build. Now even more I'm curious what the differences are between the protocol files here and in the nightly as we can't use protocols from different dfu versions.
Last edit: 02 May 2017 03:38 by Whatsinaname.
02 May 2017 04:19 #61920 by vlad_vy
There is not any differences at protocols between Nightly Build and this build, except FrskyX and Q303, they use some features that be lacking at v5.0.0.
02 May 2017 04:29 #61921 by Whatsinaname
vlad_vy wrote: There is not any differences at protocols between Nightly Build and this build, except FrskyX and Q303, they use some features that be lacking at v5.0.0.
Thank you for your confirmation. The only other variable I see is the dfu file. I don't pretend to know how the software works but I do know that the nightly didn't like my setup. And yes, I do know the nightly is even more experimental than the stable but I just thought my experience might help somewhere if any.
Again many thanks for your work here.
04 May 2017 00:52 #61977 by richardclli
Replied by richardclli on topic Deviation v5.0.0 build with latest protocols
I think vlad_vy means that his version is almost the same as 5.0 nightly, not 5.0 release. I remembered that the current nightly should applied some fixes on dsm after 5.0.release.
Am I right, vlad_vy?
04 May 2017 04:09 #61978 by vlad_vy
This build is basically v5.0.0 release with minor fixes and nightly build protocols (and telemetry) integrated.
04 May 2017 04:10 #61980 by Whatsinaname
I tried looking for the release changes pertaining to the nightly builds in regard to dsm changes and haven't found anything.
I don't mind revisiting the nightly build but now I'm awaiting my new processors for my devo7e tx's (two times) so until then I will stick with the last build from this thread.
04 May 2017 04:15 #61981 by vlad_vy
04 May 2017 04:48 #61982 by Whatsinaname
vlad_vy wrote: github.com/DeviationTX/deviation/commits...ocol/dsm2_cyrf6936.c
Many thanks! I'm gonna dig around as I didn't see the afhds2a or dsmx protocol files in that source directory.
04 May 2017 04:54 #61983 by vlad_vy
DSMX inside DSM2 file, flysky_afhds2a_a7105.c
04 May 2017 06:56 #61985 by Whatsinaname
vlad_vy wrote: DSMX inside DSM2 file, flysky_afhds2a_a7105.c
Many thanks.
So if I understand the source correctly (and I could be wrong as I haven't done any programming long enough to be proficient) the packets are built for dsm2 or dsmx during the bind process based on the protocol selected (dsm2 or dsmx).
Since the code is housed within the dsm2 c file and it checks for dsmx protocol I would assume the reason there is a dsm2 and dsmx mod file in the tx filesystem protocol folder is to allow the specification of dsm2 or dsmx which is used to bind in the selected protocol.
If this is the case...would it be neater to have a single c file (dsm.c) and in the tx protocol menu have the protocol show up as dsm with a sub setting like the orangerx setting to switch between 2 or X and then it should only need the dsm.mod file?
Just thinking out loud. If I am wrong anywhere I am always open to learning.
08 May 2017 05:55 - 08 May 2017 14:40 #62132 by vlad_vy
* Added extra channel for bayang protocol, from silver13
* AFHDS 2A telemetry update, from goebish
(08.05.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 08 May 2017 14:40 by vlad_vy.
Time to create page: 0.118 seconds
