Deviation v5.0.0 build with latest protocols
15 Jul 2017 07:09 - 01 Aug 2017 14:27 #63459 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
* Improve FrskyX extended telemetry error recovery, from hexfet
(15.07.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Files deleted, see below...
Last edit: 01 Aug 2017 14:27 by vlad_vy.
18 Jul 2017 09:25 - 19 Jul 2017 03:11 #63507 by Thomas.Heiss
Replied by Thomas.Heiss on topic Deviation v5.0.0 build with latest protocols
Hi Vlad,
do you know of any GUI code changes you may have merged into one of your latest 5.0 builds for Devo 10 (from master): www.deviationtx.com/forum/7-development/...ystem?start=80#63319
Last edit: 19 Jul 2017 03:11 by Thomas.Heiss.
18 Jul 2017 09:33 #63508 by vlad_vy
GUI code doesn't changed from v5.0.0.
01 Aug 2017 14:29 - 10 Oct 2017 05:16 #63663 by vlad_vy
* Frskyx sequence number algorithm improvement, from hexfet
(01.08.2017) Firmware DFU file only, you can get other components from official v5.0.0 release. For Devo 12e you can use Devo 10 filesystem.
Last edit: 10 Oct 2017 05:16 by vlad_vy.
08 Aug 2017 22:24 - 08 Aug 2017 22:28 #63762 by kmewes
Hi Vlad,
I just upgraded to 5.0 from 4.0.1 and now i can't change/edit the throttle and pitch curves in Advanced Mode with my Devo 8S. I used to be able to just tap the curve graphics icon which send me to edit mode Tapping doesn't work anymore. Any ideas?
Last edit: 08 Aug 2017 22:28 by kmewes.
09 Aug 2017 03:31 #63765 by kmewes
I guess this functionality has been removed and to change/edit the curves you need to tap the 'Points' bar. This might have been an option in 4.0.1 also but I always tapped the graph to enter the change/edit mode. Also it seems the function to drag the curve points when in edit mode has been eliminated. Too bad, was a nice option. I guess it took too much code space in memory. Never mind. This is a fantastic piece of code and I have been using it for years and really appreciate all the past, present and future effort of all the contributors. Many Thanks.
09 Aug 2017 04:44 - 09 Aug 2017 05:02 #63766 by vlad_vy
I use 2017-08-01 build for Devo 8s and I can edit curves by tapping curve graphics icon. I can to drag the curve points when in edit mode. What build do you use? What type of curve you can't edit?
Last edit: 09 Aug 2017 05:02 by vlad_vy.
09 Aug 2017 06:08 #63768 by kmewes
I downloaded the 2017-4-30 version since it seemed the current regular (not nightly build) release, if I'm not mistaken. Should I use a newer version like the 2017-8-5 nightly build?
And I can edit the throttle and pitch curves if I tap the 'Points' adjust bar. That kicks me to the edit mode.
09 Aug 2017 06:33 #63769 by vlad_vy
Regular v5.00 release (2016-4-30) has several bugs that fixed at "Deviation v5.0.0 build with latest protocols" builds. For example, you can't edit curves by tapping curve graphics icon. I can't say anything about nightly builds, since I don't use it.
09 Aug 2017 16:37 #63776 by kmewes
Hi, where can I download these?
09 Aug 2017 17:11 #63777 by vlad_vy
Six messages above.
09 Aug 2017 19:13 #63779 by kmewes
can you tell me please where to download your custom build 5.0.0 from?
09 Aug 2017 20:14 #63780 by kmewes
I assume it is some custom build of yours and you keep it in a different place ((-:
09 Aug 2017 20:42 #63781 by kmewes
ok never mind me just didn't look hard enough for your posts. argh.
09 Aug 2017 20:49 #63783 by kmewes
Thanks. Everything looks great again:)
13 Sep 2017 06:29 - 10 Oct 2017 05:15 #64376 by vlad_vy
* Fix sounds for devo12 "mymedia\sound.ini", from vladislavy
Changed devo12 only
File deleted, see below...
Last edit: 10 Oct 2017 05:15 by vlad_vy.
13 Sep 2017 17:20 - 13 Sep 2017 17:28 #64379 by kmewes
Can someone please fix the problem with the DSM2 protocol that still seems to exists as of NB 9-11 with the Cyclic1 and Cyclic2 being switched when using the Swash 3servo 120 setting? It seems that the Aileron and Elevator labels/assignments need to be swapped in the D/R settings. It only works for me with the Blade SR when I swap AIL from Cyclic1 to Cyclic2 and ELE from Cyclic2 to Cyclic1. This has been reported a while back. In the DR assingnments the source I need to swap the Source (Src) also for it to work. Please check and verify it if you can and apply the fix.
Thanks for the support.
Last edit: 13 Sep 2017 17:28 by kmewes. Reason: Correction
22 Sep 2017 11:07 - 04 Oct 2017 13:07 #64594 by vlad_vy
Just for fun I will add Jumper T8SG to "Deviation v5.0.0 build with latest protocols"
* RUD and AIL reversed to comply with common direction for Deviation.
T8SG based on devo7e-256 v5.0.0 build:
Last edit: 04 Oct 2017 13:07 by vlad_vy.
22 Sep 2017 11:16 #64595 by vlad_vy
Will be nice if anybody can test T8SG build and report how it works.
22 Sep 2017 19:56 #64606 by Frank mo
Replied by Frank mo on topic Deviation v5.0.0 build with latest protocols
Install, menu, model setup, etc everything work fine! Did not had time to bind it to anything yet, model config also work fine, just setup a model for simulator. Thanks for your work!!
Time to create page: 0.091 seconds
