Deviation v5.0.0 build with latest protocols
10 Jan 2018 09:03 #66798 by jpnews
Hello Vlad Vy,
I tried with the last version of Nightly Builds
versions 2018-01-03 and 2018-01-06 I have the same problem.
I came back to the 2017-12-18 version and it works fine.
I do not understand why the latest firmware versions do not work on my radio Jumper.
10 Jan 2018 09:43 - 11 Jan 2018 06:45 #66799 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
I havn't idea. From 2017-12-18 nothing changed except Frsky protocols option name "Freq-Coarse", but it do nothing with switches.
I can't reproduce it.
Try to do clean install, with USB drive format. Use "Safely remove hardware" after copy filesystem to USB drive, for safety.
P.S. Just for sure, try this build based on Nightly Builds before to do clean install, if it will work, something is wrong with Nightly Builds:
File deleted...
Last edit: 11 Jan 2018 06:45 by vlad_vy.
10 Jan 2018 12:34 - 10 Jan 2018 12:41 #66801 by vlad_vy
Just tested, I havn't any problem with my T8SG and 2018-01-06 Nightly Build.
jpnews, can you provide any screenshots with problem?
Last edit: 10 Jan 2018 12:41 by vlad_vy.
11 Jan 2018 06:43 - 01 Feb 2018 07:10 #66842 by vlad_vy
* Fix T8SG LCD_init()
(11.01.2018)
Files deleted, see below...
Last edit: 01 Feb 2018 07:10 by vlad_vy.
11 Jan 2018 08:20 #66843 by jpnews
Hello Vlad vy
I tried your latest firmware 11-01-2018 and it works on my T8SG Jumper radio.
I understood my problem with the switches that appeared in Aux. It was a problem of calibration of potentiometers AUX4 and AUX 5. As I am in mode 3 when I reload all the files the radio returns in mode 2 by default and when you return to mode 3 you must recalibrate the sticks + potentiometers AUX 4 and AUX 5.
I thank you for your support.
21 Jan 2018 09:51 - 21 Jan 2018 09:51 #67026 by kaligola
Replied by kaligola on topic Deviation v5.0.0 build with latest protocols
canot bind anymore with e010 and devo10 4 in 1 module, with nightly i could. is mandatory use nightly to use this?
Last edit: 21 Jan 2018 09:51 by kaligola.
21 Jan 2018 11:44 #67028 by vlad_vy
I don't know what can be the reason, protocols in that build havn't any difference with nightly builds.
22 Jan 2018 13:15 #67042 by kaligola
thats weird, and cannot give a check with my 7e because i dropped nfr for frsky module.
ini file was taken on forum and im sure to bet that before i flashed this latest version in this topic i did got bind, frsky and fly sky, obviously spektrum are ok.
is the fact that i used tx id to get both my radio use my flyng things without rebind?
22 Jan 2018 13:47 #67043 by Moeder
What is your txid set to? We changier the parsing of its value in hardware.ini 20 days ago for both nightly and this thread
22 Jan 2018 14:04 - 24 Jan 2018 04:09 #67044 by vlad_vy
vlad_vy wrote:
* Disable support for devo7e, due to lack of memory
* Parse txid from the hardware.ini as u32
WARNING!!! Anyone who used hardware.ini "txid" larger then 0x7fffffff will need to rebind all the receivers.
(03.01.2018)
Last edit: 24 Jan 2018 04:09 by vlad_vy.
22 Jan 2018 20:08 #67050 by kaligola
Moeder wrote: What is your txid set to? We changier the parsing of its value in hardware.ini 20 days ago for both nightly and this thread
txid = 179930CE;Only useful for transmitters with an after-market vibration motor
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13
23 Jan 2018 03:59 #67057 by vlad_vy
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
I'm not sure it will be correctly parsed. Try to change and rebind all receivers.
txid = 179930CE
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
23 Jan 2018 17:58 #67084 by Texacate
Replied by Texacate on topic Deviation v5.0.0 build with latest protocols
Is the txid line in the hardware.ini file required/recommended?
I don't have that line in my 7E hardware.ini, and am not experiencing any noticeable issues with recent protocol releases. Should I add it ? What is it used for ?
23 Jan 2018 18:12 #67085 by kaligola
seems solved now,
something must be broken on my files downloaded, downloaded again and now binds.
must check rebind on all model :dry:
now gonna check at what pioint audio topic is
thanks
23 Jan 2018 21:20 #67088 by kaligola
Texacate wrote: Is the txid line in the hardware.ini file required/recommended?
No but I got a 7e and 10, using TX id both connect to receivers as one with same id.
24 Jan 2018 03:36 #67099 by vlad_vy
It is additional line, it used if you want to use two transmitters with the same txid and use models without rebind.
24 Jan 2018 05:31 - 01 Feb 2018 07:09 #67102 by vlad_vy
I can't support devo7e as is anymore, due to lack of memory. But I can disable "Standard" GUI to save some memory, add all disabled features (except extended telemetry and language support) and continue support.
What do you think about it?
* Disable devo7e "Standard GUI"
* Enable devo7e permanent timer
* Enable devo7e layout editor
* Enable devo7e datalog
(30.01.2018)
File deleted, see below...
Last edit: 01 Feb 2018 07:09 by vlad_vy.
24 Jan 2018 07:27 - 24 Jan 2018 07:53 #67105 by Texacate
RE 7E: I'm fine without the standard GUI. I never use it. But I would hate to loose support for the 7E all together. I like the feature set you've proposed.
Last edit: 24 Jan 2018 07:53 by Texacate.
24 Jan 2018 07:59 #67107 by Texacate
vlad_vy wrote: It (TXID) is additional line, it used if you want to use two transmitters with the same txid and use models without rebind.
Thanks. I can see how that could be useful.
24 Jan 2018 08:08 #67108 by Fernandez
Replied by Fernandez on topic Deviation v5.0.0 build with latest protocols
Can someone once more explain why this topic exists? We have 15 pages of updates, due to some hard work thanks for that!!!
But why the build stay on nr 5.0.0, why not 5.0.12 etc ? I find very confusing to compare firmares and functionalities.
If we can get the voice dfplayer mod into our standard builds, possibly some manuacturars might to support it in ther new transmittters.
Time to create page: 0.085 seconds
