Where is swashmix limit in 120 mode ?
01 Nov 2012 17:43 #2583 by dado099
Where is swashmix limit in 120 mode ? was created by dado099
I notice that if I set 120 swash mode, there is only swash reverse and no
swash limit, is it true ?
How can i set max pitch and cyclic degrees ?
The only idea I have is to alter single servo limit but it's rude.
Any help ?
Thank you
01 Nov 2012 19:38 #2587 by coaster
Replied by coaster on topic Where is swashmix limit in 120 mode ?
Hi dado99
right you can do it by alter the single servo limits,
this is nothing else like the percentage limits e.g. Spektrum TX.
Keep in mind that the Mixer settings have als base the limits that you have changed. If you enter a servo limit e.g. 80% in the Mixer setup this ist 100% from the Mixer point of view
cheers
Graziano
Time to create page: 0.103 seconds
