Eclipse setup & Yagarto & STM32lib for Deviation
03 Nov 2012 16:19 #2636 by RandMental
Hi suvsuv or any other Eclipse users:
Could you please post a few more pointers to get Eclipse (Juno)C/C++, the Yagarto tool Chain and this project correctly setup?
The project builds correctly under MinGW/Misys and Yagarto, yet with my limited experience with Eclipe I get lost in all the necessary settings.
I followed your steps in the Devo 12 forum, but am not sure which toolchain to select, Mingw I guess for the emulator and the CrossCompiler chain for the DFU file.
Any help appreciated, none of the multiple Eclipse help sites got me closer to a working setup.
03 Nov 2012 16:24 #2637 by sbstnp
RandMental wrote: Hi suvsuv or any other Eclipse users:
This won't help you directly, but to be honest, the simplest way is to install Linux in a virtual machine, then get everything setup there.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
04 Nov 2012 22:34 #2681 by RandMental
Replied by RandMental on topic Eclipse setup & Yagarto & STM32lib for Deviation
Hi sbstnp
Thanks for taking the time to reply, however moving even further from my conform zone into Linux, is not really going to help. As mentioned I build the emulator and DFU files without a problem under MinGW/Mysis (on a WIN7 64Bit PC).
I need to figure out how to get Eclipse to use the correct toolchain under MinGW to build the Deviation project (after I imported it as a makefile C/C++ project.
cheers
05 Nov 2012 02:50 #2683 by suvsuv
RandMental wrote: Hi sbstnp
cheers
check out my reply here: www.deviationtx.com/forum/7-development/893-devo-12?start=20
Time to create page: 0.391 seconds
