Sound Volume
20 Nov 2012 06:45 - 20 Nov 2012 06:47 #3017 by ej189
Sound Volume was created by ej189
As I known that size of magnetic buzzers always rated a effective frequency to make louder sound. So I tested it on DEVO10 by editing \media\sound.ini to load a continued scale of sound to listen to it and I found it is frequency sensitive.
In my DEVO10, C & D scale always louder than others especially C3 and D3.
I measured the frequency by an App to get 1743Hz of C3 sound on my DEVO10, that is less than A scale a bit, don't know how it comes but it really work fine for me.
Made a louder version of sound.ini that you can try it out.
One thing about volume is that volume=0 don't turn off the buzzer when Tx start up, also volume=1 sound the same like volume=10.
Last edit: 20 Nov 2012 06:47 by ej189.
20 Nov 2012 07:16 #3018 by FDR
Replied by FDR on topic Sound Volume
Thanks, I will try it!
You can comment or delete the section you don't want, but I used to simply change the section name with a preceding underscore (or anything else) so it won't be found...
Time to create page: 0.383 seconds
