Devo 10: Curves on mixers of complex output
24 Nov 2012 23:39 - 24 Nov 2012 23:40 #3131 by domcars0
I'm unable to setup Curves on the second mixer of a complex output?
Here is my setup
GEAR => Complex (2 mixers)
* Page 1:
-Switch : None
-Mux : replace
-Src: Virt1
-Curve : 1-to-1 (but I can setup a 3 Point curve, this one is OK)
-Scale : 100
-Offset : 0
- Trim (trim of Virt1 is set on TRIM_L)
* Page 2:
-Switch : None
-Mux : add
-Src : GEAR
-Curve : 3point (But unable to ENT to setup this curve which is fixe on 0?)
-Scale : 100
-Offset : 0
-No Trim
As I do not manipulate well complex output I'n not sure that it's a bug.
If it is normal could you please explain me why?
Last edit: 24 Nov 2012 23:40 by domcars0.
25 Nov 2012 00:16 #3132 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 10: Curves on mixers of complex output
Yep it is a bug which I introduced today when I fixed another one.
I've committed a fix.
Thanks.
25 Nov 2012 03:11 #3137 by suvsuv
Replied by suvsuv on topic Devo 10: Curves on mixers of complex output
PhracturedBlue wrote: Yep it is a bug which I introduced today when I fixed another one.
Thanks.
I don't see your fix yet so I fix it in my repo. the following statement should be changed to ">="
if (mix->curve.type == CURVE_EXPO
Time to create page: 0.985 seconds
