Channel names in modelx.ini
26 Nov 2012 11:50 #3222 by Hexperience
Channel names in modelx.ini was created by Hexperience
Hi All..
I'd like to be able to rename the channels. For DSM2 the channel names are fine as are the Devo channels, but for PPM for example I can put ANY input out ANY channel, so having a predefined names is a little bit limiting. (I understand of course that this is ONLY cosmetic and has nothing to do with the values going out to the RX).
Anyway, I've kind of always preferred to just label/call them channel 1,2,3 etc rather than Thr,Ail,Ele etc. Even on my DSM setups I don't always use channel 5 for gear...
I'm sure you get what I mean... just want the option to rename "1-ELE" to Ch1 etc.
Thanks...
Time to create page: 0.591 seconds
