Temperature reading not working
- dado099
30 Nov 2012 19:08 #3462
by dado099
Temperature reading not working was created by dado099
first of all congratulations for v2 software, it's fantastic, it has everything you can need.
then a simple question:
I just upgraded devo6s with v2.0 but I have a little problem:
with 2 rxes, minicp and v120d02snew, having both temp sensors connected,
the temperature displays "----" while rx voltage is corretly displayed.
With original fw it worked correctly.
Any help ?
Thanks again.
Any help ?
Thanks again.
- suvsuv
01 Dec 2012 06:43 - 01 Dec 2012 07:15 #3485
Replied by vlad_vy on topic Temperature reading not working
With WK-CTL01-D telemetry module:
1) Only T2 sensor working. T1, T3, T4 sensors not working. Over time they show some values, even if they disconnected.
2) Volt1, Volt2 and Volt3 sensors working.
3) RPM1 and RPM2 working
4) GPS working
It is the same for all releases begin v2.0.0. Something wrong with temperature sensors.
4) GPS working
Last edit: 01 Dec 2012 07:15 by vlad_vy.
- dado099
- suvsuv
01 Dec 2012 11:43 #3488
by suvsuv
Replied by suvsuv on topic Temperature reading not working
Then try this one insteaddado099 wrote:
Thank you, but I have devo 6, the file attached seems to be for devo 8.suvsuv wrote: Try upgrade with attached dfu, it should work.
Note that in this latest version, telemetry is turned off by default, you need to turn it on in the model setup page by pressing the Devo button
- dado099
01 Dec 2012 14:17 #3496
by dado099
The curious thing is that if I set a low alarm value on Temp1 it works correctly (beeps) and correctly stops beeping if I unplug the sensor.
So it seems it reads correctly, but no display !
Replied by dado099 on topic Temperature reading not working
Thank you suvsuv, I've just tried, but it doesn't work either.suvsuv wrote: Then try this one instead
03 Dec 2012 16:44 #3580
Replied by PhracturedBlue on topic Temperature reading not working
should be fixed in the current code. the problem was a typo where we only displayed one temp in all 4 slots and if that one wasn't enabled you got '---'
Time to create page: 0.178 seconds
- Temperature reading not working
