Failsafe don't work
03 Dec 2012 07:26 #3535 by ej189
Failsafe don't work was created by ej189
Had tried on RX-2622V, RX1002, Blades NANO CPX, there will be no any action if Tx power off only.
03 Dec 2012 11:39 #3546 by Hexperience
Replied by Hexperience on topic Failsafe don't work
Are you talking about the fail safe settings in the deviation firmware? That's only for specific walkera rx's. For sure that will not work in a blade nano cpx. I don't know which rx's support getting their fail safe settings from the tx, but if you are sure that the RX1002 works with the stock firmware then we have something to compare.
03 Dec 2012 22:36 #3595 by ej189
Replied by ej189 on topic Failsafe don't work
OK, at least all Walkera receivers do support fail safe function that I used to test transmitter availible range with it.
I want to compare how the Tx power settings work that I had done on DEVO10 and WK2801 before.
04 Dec 2012 03:28 #3600 by PhracturedBlue
Replied by PhracturedBlue on topic Failsafe don't work
You are the 1st person to notice that I forgot to implement it.
I have checked in support for failsafe and tested that it works on my RX1202.
04 Dec 2012 04:37 #3603 by vlad_vy
Replied by vlad_vy on topic Failsafe don't work
PB, can you check/implement failsafe for DSM2 protocol? DSM2 receiver takes failsafe values in time of binding.
04 Dec 2012 07:56 #3611 by ej189
Thanks, got it work on DEVO at last but still don't work in 2801.
Time to create page: 1.296 seconds
