Need a suggestion please...
10 Dec 2012 01:11 #3835 by Rain4LA
Need a suggestion please... was created by Rain4LA
I'm doing a custom 450(480) build and I'm using my Devo 8s with Deviation. Any suggestions on a good, reliable, solid Rx? I already ordered a BeastX and MKS DS95/DS95i servos.
Any help would be appreciated. I've never done this before.
Thanks again.
Todd
  • rbe2012
  • rbe2012's Avatar
10 Dec 2012 06:30 #3840 by rbe2012
Replied by rbe2012 on topic Need a suggestion please...
I use three RX801 with deViation (450, 250, quadrocopter)and have never seen any failure (deViation 1.0, 1.1.2, 2.0). They have a sufficient range for a 450.
10 Dec 2012 06:49 #3843 by Rain4LA
Replied by Rain4LA on topic Need a suggestion please...
rbe2012 wrote: I use three RX801 with deViation (450, 250, quadrocopter)and have never seen any failure (deViation 1.0, 1.1.2, 2.0). They have a sufficient range for a 450.
Thank you, I appreciate the suggestion.
10 Dec 2012 10:12 #3844 by Hexperience
Replied by Hexperience on topic Need a suggestion please...
Going off topic a bit, but I don't understand why Walkera can make a micro RX/Gyro like the ones in the V120 that has telemetry, but the Rx801 (rx802?) don't have telemetry?
For anything other than micros I use FRSky. Fantastic range (unofficially up to 5Km!) built in telemetry and cost about $20 US for a 6 channel, $25 for an 8 channel.
I'm going to attach an FRsky module to my devo 8s. The module takes PPM so it's easy to do, but it would/will be great when FRSky is integrated into deViation so we get telemetry on screen.
Walkera needs a new head of marketing. They could be a much bigger player in the market, but they are all over the place in terms of marketing strategy.
10 Dec 2012 23:38 - 10 Dec 2012 23:39 #3861 by Rain4LA
Yeah, Walkera is definitely driven. It's just that their direction seems scattered. There seems to be a little madness in the mix. But they do make a few good products. And I'm not so against the V450D03 like some people are. It seems like a solid helicopter for the price. And for what it's worth, I like the way my genius v2 and V120D02S hold. They feel stable. I'm still new, so I don't have a lot to compare to.
Last edit: 10 Dec 2012 23:39 by Rain4LA.
10 Dec 2012 23:50 #3862 by PhracturedBlue
Replied by PhracturedBlue on topic Need a suggestion please...
Hexperience wrote: I'm going to attach an FRsky module to my devo 8s. The module takes PPM so it's easy to do, but it would/will be great when FRSky is integrated into deViation so we get telemetry on screen.
Note that when I get to FRSky, it will be with a CC2500 module. That means you likely won't get the same range unless you can find a module with a serious PA.
11 Dec 2012 15:21 - 11 Dec 2012 15:22 #3878 by Hexperience
I'm going to build a nice module holder and use PPM to control external modules. That's one of the things I really love about the 9x.
The only thing holding me back right now is the power. I'm not sure the best way to power both the 8s and the modules. FRSky say the min. voltage is 6. I know it will probably run fine at lower, but I'm thinking I'll run at least 2s and use a UBEC to supply the 8s with a constant 5 or 6v
ps. My v450d03 is in the mail... happy holidays!! ;)
Last edit: 11 Dec 2012 15:22 by Hexperience.
12 Dec 2012 06:13 #3905 by Hexperience
Getting back to the RX topic... I have two rx2702v's coming in the mail, and I just got an rx2618v-d.
I plan to try the rx2618 in my 250 if I can get the servos worked out. There's not much in the way of setup on the rx2618 as far as reversing.
I will also try the rx2702 in the 250 and compare them. And I have a 2703H coming (included in the v450d03).
I have an ar7200bx in my blade 300x, and a CopterX 3x1000 in my 450 and 500. The problem is, I'm not a good enough pilot to compare all these gyros and rx's. I pretty much can only do circuits, I'm just starting to try flips.
Anyway, I can of course compare hard pitch pumps and how well the tail holds, and how stable they feel in hover. But it all comes down to setup and flight style. I'll bet my $30 copterx gyro can be setup and feel more stable than the $300 ar7200bx. The ar7200bx of course might feel much better to someone doing "tock-ticks" or whatever you call them... ;)
12 Dec 2012 07:06 #3906 by magic_marty
Replied by magic_marty on topic Need a suggestion please...
careful with the 3x1000 ....i had one burn out my tail servo and cause a crash..better off going with a higher end gyro.
12 Dec 2012 09:30 #3907 by domcars0
Replied by domcars0 on topic Need a suggestion please...
magic_marty wrote: careful with the 3x1000 ....i had one burn out my tail servo and cause a crash..better off going with a higher end gyro.
I agree with.... 3x1000 is not safety at all.
Time to create page: 0.908 seconds
