Question about 130x
- Parees
14 Dec 2012 08:16 #3992
by Parees
Question about 130x was created by Parees
For the 130x, to enter the gyro gain programming mode, we need to keep the throttle stick high (at100%) and then plug in the battery into the 130x. Will this work with the Devo Tx with deviation?
I believe Devo Tx (without deviation) has a built in safety feature whereby the Tx will not bind with a heli if the throttle is not zero. So this can potentially prevent the 130x from entering the gyro gain programming mode, unless deviation has somehow bypassed this limitation.
- sbstnp
14 Dec 2012 10:00 #3993
by sbstnp
You can press ENT and get rid of the warning.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Question about 130x
Parees wrote: For the 130x, to enter the gyro gain programming mode, we need to keep the throttle stick high (at100%) and then plug in the battery into the 130x. Will this work with the Devo Tx with deviation?
Devo 10 + 4in1
14 Dec 2012 11:07 - 14 Dec 2012 11:08 #3994
Replied by vlad_vy on topic Question about 130x
Definitely this will work. I calibrated throttle at mQX (add other UMX models) with the same procedure.
Last edit: 14 Dec 2012 11:08 by vlad_vy.
- Hexperience
14 Dec 2012 11:10 - 14 Dec 2012 11:31 #3995
by Hexperience
Replied by Hexperience on topic Question about 130x
Using a fixed id to bind it first should work. Then unplug the heli battery and plug it back in. ?
I haven't tried it, and to be honest, the last couple of times I've tried to fly my ncpx I've had to rebind it to get it to work.
Let us know how it goes...
Cheers
Cheers
Last edit: 14 Dec 2012 11:31 by Hexperience.
- Parees
14 Dec 2012 19:32 #3999
by Parees
Replied by Parees on topic Question about 130x
I've ordered a Devo 8s and it's still on the way. I'll try this once I receive it and let you know how it goes. From your replies it looks like it should work.
- Parees
14 Dec 2012 22:16 #4001
by Parees
Vlad_vy, I was curious where you came across your method of calibrating the throttle for the mqx? I've been googling "mqx throttle calibration" and I only see two posts, both from you
www.rcgroups.com/forums/showthread.php?t=1563931&page=436
www.deviationtx.com/forum/3-feedback-que...ith-blade-mqx-rebind
- Hexperience
14 Dec 2012 22:46 #4002
by Hexperience
This forum and that thread on RCG is the only place you'll find stuff about deViation....
The few, the proud... this is all new ground we're walking on. If you figure out a way to do something, post it here because there is no other source of information.
15 Dec 2012 06:34 - 15 Dec 2012 07:41 #4007
I don't been confident it's really working for Blade mQX up to case at this topic:
But I always try to do calibrate throttle this way, if I have any problems/inconsistences at throttle channel with my ultra micro models.
Last edit: 15 Dec 2012 07:41 by vlad_vy.
Time to create page: 0.418 seconds
- Question about 130x
