Module from align 100x tx
- bigde
29 Dec 2012 19:49 #4365
by bigde
Module from align 100x tx was created by bigde
Module from align 100x tx binds with all turnigy (Flysky)stuff but look a bit different than what is shown in flysky to devo pdf manual. Did any of you setup with one of these... The manual is showing page8 flysky module connected to the devo and two wires from the devo going out of picture connect to what...
are they there for test to power on? I wish there was a video on this.
- sbstnp
30 Dec 2012 05:03 - 30 Dec 2012 07:05 #4367
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Module from align 100x tx
Check this doc:
www.deviationtx.com/repository/Documenta.../Flysky-to-Devo.pdf/
See if you can identify pins, post some pictures of your module, maybe we can help.
Devo 10 + 4in1
Last edit: 30 Dec 2012 07:05 by sbstnp. Reason: Fixed link
- bigde
30 Dec 2012 22:11 #4392
by bigde
Replied by bigde on topic Module from align 100x tx
I have check the flysky manual. The two wire that go out of the pict across devo module are for what on page 8. And is there a switch to select which module to select or the 2 module are on at the same time all the time.
- Wene001
30 Dec 2012 23:04 - 30 Dec 2012 23:15 #4394
by Wene001
Replied by Wene001 on topic Module from align 100x tx
The Modules are turned on or off by the Software
e.g. if PPM is selected both modules are off
and if Flysky is selected Devo Module is off and only the Flysky Module is on
and so on
The two wires are connected to the unused debug port on the motherboard (tmc...)
to control the modules separetly
rtfm
Greetz Werner
and so on
rtfm
Greetz Werner
Last edit: 30 Dec 2012 23:15 by Wene001.
- bigde
31 Dec 2012 05:25 - 31 Dec 2012 05:28 #4401
by bigde
I've did it and it fucking works...
I'm just happy. I was scare
that it would go up in smoke but no it all work good. I've bound it to my Align 100x and it work. I just have to configurate it. Now I will be able to run my wl v929 quadcopter and my Align 100x. Thanks a lot I'm really happy.
Last edit: 31 Dec 2012 05:28 by bigde.
- bigde
31 Dec 2012 05:39 - 31 Dec 2012 05:59 #4402
by bigde
My devo8s is going to be my favorite tx. Now I wish that we could do the same for my wl v922 that's coming in the mail... that would be awesome. I saw that their new TX is not compatible with flysky.
Last edit: 31 Dec 2012 05:59 by bigde.
31 Dec 2012 06:27 #4403
Replied by PhracturedBlue on topic Module from align 100x tx
I've got a v922 coming too. It uses a different module I believe, so it'll require a similar but different modification.
Stay tuned.
Stay tuned.
- bigde
31 Dec 2012 19:01 #4444
by bigde
OK thanks.. I looking forward to a cheap alternative to mcpx something with cheap parts. I was wondering if you would know for the aligne 100x the tail gyro is adjustable,... which chanel you think that would be cause that tail is just buzing and shaking. Thanks alot and happy new year.
01 Jan 2013 10:56 #4465
Replied by rbe2012 on topic Module from align 100x tx
I think I have read somewhere that the first version of the trex 100 (x or s) had problems with the tail stability. Maybe it's no problem you can resolve with the tx...
Time to create page: 0.608 seconds
- Module from align 100x tx
