How have i to connect WK-CTL01-D ?????
31 Dec 2012 17:17 #4433 by Fussi
i have walkera v450d03 with RX2703H-D receiver and Devo 8s.
My question please: How to i have to connect the telemetry module WK-CTL01-D ?? Is this possible with RX2703H-D ?
Thank you for answering.
Regards
Christian
31 Dec 2012 19:20 - 31 Dec 2012 19:22 #4445 by Hexperience
Replied by Hexperience on topic How have i to connect WK-CTL01-D ?????
I don't think you need to connect it to the RX at all. I haven't got one yet. I think $50 is a little much for telemetry now that a lot of RX's have some basic telemetry built in.
Anyway, from what I can see all you need to do is supply it power. You can do that in a number of ways, but I guess the easiest would be to run a female-female servo cable between the RX and the telemetry unit. But you can/should remove the signal wire and just have the red and black wires.
Let us know how it works out. I'm interested in this as well.
Cheers
Last edit: 31 Dec 2012 19:22 by Hexperience.
31 Dec 2012 20:00 - 31 Dec 2012 20:10 #4446 by Fussi
Replied by Fussi on topic How have i to connect WK-CTL01-D ?????
Thank you very much for reply. My doubts are, that i can not connect the cable to rx, because the free (rest) of connections to have no power (Walkera RX2703H-D)
Last edit: 31 Dec 2012 20:10 by Fussi.
31 Dec 2012 20:40 #4447 by Fussi
Hi Hexperience, you wrote: "I don't think you need to connect it to the RX at all."
And: "run a female-female servo cable between the RX and the telemetry unit."
That is a contradiction
31 Dec 2012 21:26 #4448 by Hexperience
Right, sorry. I meant that there is no data connection required. But that you could get power from the rx. I'm very surprised to hear there is no power on the unused ports on the rx.
Another way to get power would be to use a y split cable on the esc to get power into the telemetry unit.
01 Jan 2013 09:00 #4461 by Fussi
Thank you for reply. Yes, i will try that.
I wish you a happy NEW YEAR !!!
23 May 2013 14:13 - 23 May 2013 14:15 #10252 by Hexperience
Just coming back here to update, I now have two of the walkera telemetry units. I only buy them when they are on sale somewhere, but I thought about it a bit more and compared it to what spektrum is doing for telemetry and I don't think it's that bad a deal. Compared to Frsky, which has voltage built in, yes, it's a pain. But compared to the telemetry modules and expense of spektrum I'm not unhappy.
And they work perfectly by the way. Because I get alerted to voltage rather than a timer, I found I can get 11 minute flights on my v450d03 with the battery I have. And still leave 3.6v per cell.
PS. Don't you love it when you are google'ing something and it brings you back to your own posts... ;)
Last edit: 23 May 2013 14:15 by Hexperience.
26 Jan 2014 19:34 #19195 by joestefano
Replied by joestefano on topic How have i to connect WK-CTL01-D ?????
How do I get the Information from the CTL01 to display on my F7 screen? I can see the info in the "sensor view" under the function menu,but thats it.
26 Jan 2014 20:05 #19205 by FDR
Replied by FDR on topic How have i to connect WK-CTL01-D ?????
I'm afraid, that you can't put telemetry data on the main page...
27 Jan 2014 04:11 - 27 Jan 2014 04:11 #19255 by henkerhaus
Replied by henkerhaus on topic How have i to connect WK-CTL01-D ?????
You can add a box, and then assign it to display TelemV1, TelemV2, TelemV3, TelemT1, TelemT2, TelemT3, TelemT4, TelemRPM1, or TelemRP2. No GPS Data though.
Last edit: 27 Jan 2014 04:11 by henkerhaus. Reason: Fixed typo
27 Jan 2014 05:12 - 27 Jan 2014 05:12 #19257 by FDR
He is asking about the F7, so no deviation yet...
Last edit: 27 Jan 2014 05:12 by FDR.
27 Jan 2014 08:58 #19261 by RandMental
Replied by RandMental on topic How have i to connect WK-CTL01-D ?????
I have not tested Walkera telemtry on V4.0.1, but it did worked before as Henkerhaus also mentioned (Devo8s)
Time to create page: 0.302 seconds
