Trims... bugged or am I missing something?
02 Jan 2013 05:21 #4504 by MatCat
Using the current release of the firmware, I setup a standard airplane but with ailerons on seperate channels, I did the mixing for the ailerons which was simple enough, but then I noticed my trims don't work for anything (except aileron, and I did not test throttle), though subtrims work fine... I checked trim settings and they all appear to be proper, and even the trim indicator moves around so the system recognizes the trims, but no trimming actually goes out to the servos. I tried resolutions of trim step from 0.1 to 1.
02 Jan 2013 05:27 #4506 by vlad_vy
02 Jan 2013 20:57 #4531 by MatCat
Replied by MatCat on topic Trims... bugged or am I missing something?
I am using a simple mix not complex... hrm, I guess I need to switch to complex... Simple should have trim settings though...
02 Jan 2013 21:08 #4532 by Hexperience
Replied by Hexperience on topic Trims... bugged or am I missing something?
Post your ini file, could be a bug, you never know.
Time to create page: 0.100 seconds
