How can I tell if my throttle stick is faulty?
16 Jan 2013 01:57 #5051 by Rain4LA
My throttle stick (left - mode 2) just may be the main issue that's been causing the weirdness in my Devo 8s. I've noticed that whether it's a Blade, or a Walkera the pitch seems to stick, then suddenly pop up when it "catches" or whatever is going on. Could this possibly be a hardware issue? Namely, the throttle stick?
I would really appreciate any help. Thanks guys.
  • rbe2012
  • rbe2012's Avatar
16 Jan 2013 06:52 #5054 by rbe2012
Can you post your model.ini? There is a known bug in 2.1.0: in a complex mixer every page must have a switch assigned. This is automatically set to AIL so the mixer might not generate output unless you move the aileron stick.
As a workaround you can use FMOD0 as switch for the first mixer page (assuming a standard configuration with FMOD1, FMOD2 on pages 2 and 3).
16 Jan 2013 14:52 #5065 by Rain4LA
rbe2012 wrote: Can you post your model.ini? There is a known bug in 2.1.0: in a complex mixer every page must have a switch assigned. This is automatically set to AIL so the mixer might not generate output unless you move the aileron stick.
It's not just one .ini file. It's like every one that I use. Some for Walkeras, other for Blades. They seem to want to exhibit the same characteristics - which are mentioned above....
  • rbe2012
  • rbe2012's Avatar
16 Jan 2013 16:05 #5067 by rbe2012
Have you looked at the complex mixer? The behavior changed invisibly when you load an existing (before 2.1.0) model.
Time to create page: 0.291 seconds
