Walkera devention dexo 7 reset
- weese
19 Jan 2013 08:51 #5178
by weese
I have a devo 7 transmitter - the radio only comes on with a screen which say's thhld thstk I am unable to change to anything else. I belive the radio reset function has been hit. Can anyone tell how to reset the transmitter to factory specs?
Walkera devention dexo 7 reset was created by weese
19 Jan 2013 09:33 - 19 Jan 2013 13:11 #5179
Replied by vlad_vy on topic Walkera devention dexo 7 reset
Possible you need switch off 'Trottle Hold' switch and lower throttle stick to minimum.
Last edit: 19 Jan 2013 13:11 by vlad_vy.
- weese
19 Jan 2013 12:40 - 19 Jan 2013 12:43 #5187
by weese
Replied by weese on topic Walkera devention dexo 7 reset
Throttle hold is switched off and the screen shows THSTK and will not allow any other input or menu... Im pulling my hair out ... what little is lef
Last edit: 19 Jan 2013 12:43 by weese. Reason: type
19 Jan 2013 12:54 #5188
Replied by PhracturedBlue on topic Walkera devention dexo 7 reset
move the throttle stick all the way down. if that doesn't work, move the elevator all the way down (maybe you're in the wrong mode)
- weese
19 Jan 2013 13:11 #5190
by weese
THAT DID THE TRICK... I can't tell you how much that helped me now I can try to get more stitches in my back again THANKS FOR THE HELP WOW look out world!!!
Time to create page: 0.395 seconds
- Walkera devention dexo 7 reset
