Walkera devention dexo 7 reset
19 Jan 2013 08:51 #5178 by weese
Walkera devention dexo 7 reset was created by weese
:( I have a devo 7 transmitter - the radio only comes on with a screen which say's thhld thstk I am unable to change to anything else. I belive the radio reset function has been hit. Can anyone tell how to reset the transmitter to factory specs?
19 Jan 2013 09:33 - 19 Jan 2013 13:11 #5179 by vlad_vy
Replied by vlad_vy on topic Walkera devention dexo 7 reset
Possible you need switch off 'Trottle Hold' switch and lower throttle stick to minimum.
Last edit: 19 Jan 2013 13:11 by vlad_vy.
19 Jan 2013 12:40 - 19 Jan 2013 12:43 #5187 by weese
Replied by weese on topic Walkera devention dexo 7 reset
Throttle hold is switched off and the screen shows THSTK and will not allow any other input or menu... Im pulling my hair out ... what little is lef
Last edit: 19 Jan 2013 12:43 by weese. Reason: type
19 Jan 2013 12:54 #5188 by PhracturedBlue
Replied by PhracturedBlue on topic Walkera devention dexo 7 reset
move the throttle stick all the way down. if that doesn't work, move the elevator all the way down (maybe you're in the wrong mode)
19 Jan 2013 13:11 #5190 by weese
THAT DID THE TRICK... I can't tell you how much that helped me now I can try to get more stitches in my back again THANKS FOR THE HELP WOW look out world!!!
Time to create page: 0.199 seconds
