Critical Error in DeViation 2.1.0 (Channel Config)
20 Jan 2013 13:55 - 20 Jan 2013 13:58 #5245 by Tom_ate
This is to give you information about a critical error in DeViation 2.1.0 (released Version from 16. Dez. 2012) on Devo10. It has caused an unexpected motor start in my case - but no damage :-)
This is what gone wrong:
Mixer-Menu: Go to "Channel Configuration page" (= input channel) and enter different values for positive and negative scale on the throttle channel.
Then all is fine and the different scales are used properly.
Then power off and repower on the TX (or reload the file)
After that the negative Scale is no longer a separate number - the +Value is also used for the -value instead.
I have no clue if this error is also occuring with other channels. Also I do not no if the error is also occuring with other devos then Devo10.
PS: I also reported it on bitbucket.
Kind regards,
Matthias
Last edit: 20 Jan 2013 13:58 by Tom_ate.
20 Jan 2013 15:03 #5247 by thloh85
I can reproduce this bug.
20 Jan 2013 15:11 #5249 by PhracturedBlue
Replied by PhracturedBlue on topic Critical Error in DeViation 2.1.0 (Channel Config)
This is fixed in v2.1.1
It only happened when the negative scale was 100 and the positive scale was another value.
If you still see the issue with v2.1.1 then I need more details on exactly how to reproduce.
20 Jan 2013 15:27 #5251 by Tom_ate
You are right: My negative scale was -100 and my positive scale was 70.
Many thanks!!
Kind regards,
Matthias
Time to create page: 0.300 seconds
