Are these Devo Rx's PPM?
20 Jan 2013 18:15 - 20 Jan 2013 18:17 #5277 by Rain4LA
Are these Devo Rx's PPM? was created by Rain4LA
If it sounds like a newby question - it is... But I'm setting up my BeastX and need to make sure. Thank you!
By the way - I'm using a 12s and RX1202 with the standard Devo firmware on this build, if that matters.... :)
Last edit: 20 Jan 2013 18:17 by Rain4LA.
20 Jan 2013 18:25 #5278 by Rain4LA
Replied by Rain4LA on topic Are these Devo Rx's PPM?
I need to either tell it "standard" or "PPM", which I'm sure is obvious to anyone who would be reading this. I can't find a manual anywhere for this receiver - so I really don't even know how the channels are assigned.
20 Jan 2013 19:26 #5282 by Hexperience
Replied by Hexperience on topic Are these Devo Rx's PPM?
It would be standard. Ppm would send the data out of the trainer jack.
My devo 12s is on its way.... :)
21 Jan 2013 00:34 #5291 by Rain4LA
The 12s is AWESOME! I'm gong to use it for all things DEVO, and my 8s for everything else. You'll notice the difference in the 12s on your Walkera helicopters. I'm building the ALZRC Devil 480 (with BeastX) and using the RX1202 with 12s. I think it's gonna rock. I'm pretty sure of it. Thanks for your help, Hex.
10 Nov 2013 09:17 #15486 by soonglim
Replied by soonglim on topic Are these Devo Rx's PPM?
I just posted a question:
www.deviationtx.com/forum/3-feedback-que...ns/2351-rx1202#15485
Then I saw your post with setting up the rx1202 with devo 12s. Would you happen to have run into same issue I did or did it worked for you right out of the box?
Thanks in advance for any help or suggestions.
Time to create page: 0.477 seconds
