Wk2801 Tail gain not working
22 Jan 2013 14:47 - 22 Jan 2013 14:50 #5369 by digitracer
Wk2801 Tail gain not working was created by digitracer
I have a strange problem with my config file for a Walkera 4f200 (see attached ini file).
File Attachment:
File Name: model2.ini
File Size:8 KB
I have put an exp/dr mixer on channel 7 to switch between HH and rate (normal) mode which is by default 80% vs 20% gain. So far so good, the red light on the receiver is switching on and off accordingly, but on HH the tail spins slowly ccw no matter which mode you are in or gain you are selecting.
On zero throttle the slider on the tail shaft reacts differently though. On HH mode it slides totally to the left (viewed from the back) while it centers perfectly on normal mode after initializing.
If I use an WK2801 there is no tail spin on HH at all, the tail holds perfectly solid.
Has anyone got a clue what this can be? I am driving nuts for days already.
Thanks a lot!
Last edit: 22 Jan 2013 14:50 by digitracer.
Time to create page: 0.089 seconds
