Can not install V 2.1.1 on Devo 6.
- LeGriffon
31 Jan 2013 23:55 #5869
by LeGriffon
Can not install V 2.1.1 on Devo 6. was created by LeGriffon
I currently fly with V 1.1.2 on my Devo 6 and I try to install new version 2.1.1 but it do not work. After loading TX seems to reboot in dead loop. Any suggestion ?
Thanks in advance for help, and for this very nice software.
Rgds
Pascal.
Rgds
Pascal.
01 Feb 2013 01:33 - 01 Feb 2013 01:35 #5870
Replied by PhracturedBlue on topic Can not install V 2.1.1 on Devo 6.
1) Hold ENT on power up and make sure USB mode works. If not, redownload and re 'upgrade' the firmware
2) if usb mode works, make sure to copy the 2.1.0 devo8 filesystem (preserve your models though)
I think others have also mentioned issues for the devo6. I don't have one so I can't verify it works, but there should be no difference between the 2.1.0 and 2.1.1 release.
If neither 1 or 2 works, try 2.1.0 and see if it works for you.
Last edit: 01 Feb 2013 01:35 by PhracturedBlue.
- LeGriffon
01 Feb 2013 18:54 #5889
by LeGriffon
Replied by LeGriffon on topic Can not install V 2.1.1 on Devo 6.
I got it... it is tricky, but you have to press and hold the enter key to enter and stay in USB mode (USB symbol is display on TX screen), and then after copy the new FS files it works.
Next step telemetry. Telemetry monitor menu says Telemetry is not supported, when I understood that one of the goods news of V2.1.1 is telemetry... Is there something to do to able it ? (of course my Devo6 is S one and got telemetry module).
Thanks for help.
Rgds
Pascal.
Thanks for help.
Rgds
Pascal.
- domcars0
01 Feb 2013 19:56 - 02 Feb 2013 09:58 #5890
by domcars0
Replied by domcars0 on topic Can not install V 2.1.1 on Devo 6.
Which protocol have you configured for your model?
Last edit: 02 Feb 2013 09:58 by domcars0.
- LeGriffon
01 Feb 2013 23:29 #5896
by LeGriffon
Thanks,
Telemetry depends on models... If I use a devo RX601 model I can open the menu now. Thanks for help.
Rgds
Pascal.
Rgds
Pascal.
- domcars0
02 Feb 2013 09:59 #5904
by domcars0
No, I think telemetry depends on protocol ...
Welcome,LeGriffon wrote: Thanks,
02 Feb 2013 10:39 #5905
Replied by FDR on topic Can not install V 2.1.1 on Devo 6.
...but can be enabled/disabled by model.
- domcars0
02 Feb 2013 14:38 #5906
by domcars0
rightFDR wrote: ...but can be enabled/disabled by model.
Time to create page: 0.599 seconds
- Can not install V 2.1.1 on Devo 6.
