Trainer Port on Devo 8 - in DSM mode
- clearprop88
02 Feb 2013 19:09 #5914
by clearprop88
Trainer Port on Devo 8 - in DSM mode was created by clearprop88
This may have been addressed before, but I couldn't find the post.
Can I hard wire between the trainer ports on a Spectrum DX8, and my Devo 8 (in DSM protocol), and have them function as Master,and slave for training?
02 Feb 2013 19:14 #5915
Replied by FDR on topic Trainer Port on Devo 8 - in DSM mode
So far deviation only supports PPM out, and you have to change the protocol to achieve it, but at least you can make the PPM signal and the channel order to be appropriate for the DX8.
- clearprop88
02 Feb 2013 20:43 #5917
by clearprop88
Replied by clearprop88 on topic Trainer Port on Devo 8 - in DSM mode
Let me see if I understand.
If I use my model config for my Blade 300X, and then change to PPM instead of DSM then it will work in trainer mode.
Is this correct?
Is this correct?
02 Feb 2013 20:59 #5919
Replied by rbe2012 on topic Trainer Port on Devo 8 - in DSM mode
I did not try this by myself, but deViation can only work as master at the moment.
- clearprop88
02 Feb 2013 22:04 #5926
by clearprop88
OK, thanks. I guess I'll just stay away from it for now, and stay with Spectrum TX's.
- Hexperience
02 Feb 2013 22:18 #5927
by Hexperience
Replied by Hexperience on topic Trainer Port on Devo 8 - in DSM mode
No. Devo is the skave. Just send ppm out the trainer port just like you would to a simulator. All that you send is the stick data the dx8 does thw rest
- clearprop88
02 Feb 2013 23:21 #5930
by clearprop88
That's just what I wanted, to use my Devo as the slave.
Thanks Hexperience.
I'll give it a try during the week, and report how it goes.
Thanks Hexperience.
- Hexperience
02 Feb 2013 23:30 #5931
by Hexperience
Obviously test it first, I've never tried trainer mode on a 6 channel heli, so you need to make sure that pitch and throttle are correctly mapped. If you are just doing a 4 channel plane its pretty straight forward.
- clearprop88
03 Feb 2013 02:02 #5937
by clearprop88
That's exactly what we'll do. 4 Ch plane first then heli.
03 Feb 2013 08:31 #5952
For sure. The master is the one who controls the ppm input. Sorry for the mixup.Hexperience wrote: No. Devo is the skave.
Time to create page: 0.132 seconds
- Trainer Port on Devo 8 - in DSM mode
