Bug mixer pitch curve devo8 deviation 2.1.1
13 Feb 2013 19:30 - 13 Feb 2013 19:33 #6369 by Boni7league
Bug mixer pitch curve devo8 deviation 2.1.1 was created by Boni7league
Hello ,when I select the curve 2 3 or 4 in pitch curve mixer and I want to assign the right switch ( example fmod1 ) when I touch the selection arrow bug the product and the screen turns off and on but the home screen and all that I have done in the mixer page it is clear and I have to start over , I do not know if there are other bug , I can handle a normal curve and this is annoying , what to do ? thank you in advance . sorry posting in the wrong section.
Last edit: 13 Feb 2013 19:33 by Boni7league.
29 Mar 2013 21:53 #8256 by Gerhard_H
Replied by Gerhard_H on topic Bug mixer pitch curve devo8 deviation 2.1.1
Hi !
Downloaded v.2.1.1 (new Devo_8S) today and met exactly the same problem as Boni7league has reported.
Wrong procedure (via mixer) ? Or have I to go via Expo&DR menu ?
Any feedback would be appreciated.
tia
Gerhard
29 Mar 2013 22:15 #8258 by domcars0
Replied by domcars0 on topic Bug mixer pitch curve devo8 deviation 2.1.1
It's an old bug which is corrected now. Install a 'Nightly Build' or wait few days, the V3.0.0 will be here soon!
29 Mar 2013 22:25 #8260 by Gerhard_H
OK, thanks a lot !
Gerhard
31 Mar 2013 11:28 - 31 Mar 2013 11:29 #8337 by Gerhard_H
Hi !
Yesterday late in the evening I programmed the miniCP strictly following the manual (downloaded from (Main Menu/User Manual). And I was able to programme the throttle curve the "complex" way (4 pages), I did have access to the referring switches without the screen turning off. After I had programmed the gyro everything seemed to be allright. I was able to fly the heli.
Thought I had got it.
Went to programme the Genius (V2) exactly the same way.
Same drama as usual. Programming the "complex" throttle - when I want to choose the proper switch on page 2 or 3 or 4 programming exits. Strange : I can do it on page 1.
Why did it work one time and the other it didn't ?
Totally confused . . .
Notice :
The "complex" Throttle programming procedure I had mentioned can be found on the "Deviation Firmware User's Manual Version 2.0" on page 29.
Regards
Gerhard
Last edit: 31 Mar 2013 11:29 by Gerhard_H.
31 Mar 2013 20:09 #8345 by Gerhard_H
Hi !
Following domcars0's advice I loaded the last Nightly Build and now it seems to work fine. I now run 2801, Devo and NineEagles helis.
Time for me to say thanks a lot to the maker(s) of this software.
Regards
Gerhard
Time to create page: 0.193 seconds
