Why deviation-devo7e-b1b5bcecde6b.zip doesn't work
25 Feb 2013 14:20 #7026 by galee
I have download <deviation-devo7e-b1b5bcecde6b.zip> from here:
www.deviationtx.com/repository/Deviation...7e-b1b5bcecde6b.zip/
Submitted By: PhracturedBlue (PhracturedBlue)
Submitted On: 25 Feb 2013
File Size: 319.1 KB
it seems to be uploaded today, after upgrading finished, I found my DEVO7E can not bind with my reciever(DEVO RX1002), then I return it to official firmware, it works: bind ok.
I have not test any other reciever (because I haven't now).
Does anyone test? or can I burn any other firmware for a test?
25 Feb 2013 14:33 #7028 by galee
I just try the firmware from www.deviationtx.com/forum/7-development/1230-devo7e-work , it still not work.
my resource file to the TX-DISK is from D10 like this:
The main page is:
The model set and bind interface:
My rx is:
25 Feb 2013 15:05 #7029 by domcars0
Is your RX binded on your Devo7e deVention with a fixed Id ? If yes, I think you've to manually 're'bind it with deViation...
(I never though that a 10 channels devo RX could bind with a 7 channels Devo TX with deVention?)
25 Feb 2013 15:06 #7030 by vlad_vy
Can you verify that you have not setup 'Fixed ID' at original firmware Tx?
25 Feb 2013 15:18 - 25 Feb 2013 15:20 #7031 by galee
hi, domcars and vlad_vy, thanks for reply
1. About issue RX10CH with TX7CH...... it do work when the DEVO7E has an official firmware ver0.1, and I just buy them together ^_^
2. I use a bind-plug clear the FIXED-ID in the RX before binding operation.
Last edit: 25 Feb 2013 15:20 by galee.
25 Feb 2013 15:31 - 25 Feb 2013 15:32 #7033 by vlad_vy
Do you use 'protocol' folder from the same .zip file (build)? File .dfu and 'protocol' folder have to be from the same build.
Last edit: 25 Feb 2013 15:32 by vlad_vy.
25 Feb 2013 15:35 #7034 by Xermalk
vlad_vy wrote: Do you use 'protocol' folder from the same .zip file (build)? File .dfu and 'protocol' folder have to be from the same build.
Theres a check implemented now so if the wrong protocol files are used you get a warning.
25 Feb 2013 15:45 #7038 by PhracturedBlue
Replied by PhracturedBlue on topic Why deviation-devo7e-b1b5bcecde6b.zip doesn't work
does it work if you clear the fixed-id from the tx and the rx and let it do binding during power-on?
26 Feb 2013 02:38 #7057 by galee
Yes, I just try a wrong version protocol and got a warning dialog:
so I'm using the correct protocols.
26 Feb 2013 02:42 #7058 by galee
I have try and confirm the problem is just like you say!
when I set a FIXED-ID, it can not bind with RX anyway:
Then I clear the FIXD-ID, the caption of BIND button changed to 'Re-Init', when pressed, RX bind OK and work well~
I have also try AUTO-BIND on boot, it work well too.
So the problem seems to be a little BUG of FIXED-ID.
26 Feb 2013 07:44 #7066 by domcars0
Did you well put the short wire strap on the RX when you change the fixed ID?
26 Feb 2013 08:43 #7068 by galee
re: domcars0
no, I just plug the shorter and poweron RX, when RX LED flash slowly (indicate ID in RX is cleared), I have removed the shorter (BIND Plug), then turn on TX to operate...
In a word, in my test, every time I want to make a binding, a clear operate is always be done in RX, and "NONE-ID" is ok but "FIXED-ID" will fail.
26 Feb 2013 10:09 #7070 by domcars0
galee wrote: re: domcars0
This is what I meant
Time to create page: 1.302 seconds
