- Is there support for EZ uhf Rx or Dragonlink?
- Rain4LA
13 Mar 2013 16:05 #7692
by Rain4LA
Is there support for EZ uhf Rx or Dragonlink? was created by Rain4LA
Just wondering what modifications would need to be done to use my 8s for FPV. I'm building a quad and my video equipment will go much further than my aircraft!
- Rain4LA
14 Mar 2013 13:34 #7745
by Rain4LA
Replied by Rain4LA on topic Is there support for EZ uhf Rx or Dragonlink?
I'm really just looking for info on weather it would be easier to use my Devo 8s with Deviation for a UHF set to piggy back on - or if it doesn't make any difference if I use my regular 12s (Devention f/w). I haven't done this before, and I know that these systems use PPM outputs from almost any radio. I just don't know if there's an advantage to one or the other. So if anyone has experience with these types of things, I would really appreciate any feedback. Thanks!
14 Mar 2013 13:38 #7747
Replied by FDR on topic Is there support for EZ uhf Rx or Dragonlink?
The main difference is that the original fw would use EATR channel order in it's PPM output, while with deviation you have full control over which channel does mean what.
The question is, what does your UHF set need?
14 Mar 2013 13:40 #7748
However deviation doesn't yet support PPM in, so you can't send out the headtracking info...
- Rain4LA
14 Mar 2013 15:06 #7752
by Rain4LA
Oh, okay... Does the regular Devention support the PPM in? My manual seems lacking in pertinent info. Thank you...
And I'm not sure what the UHF set needs because I haven't ordered one yet. There is so much stuff to figure out.
Time to create page: 0.578 seconds
