Binding problem with DSM2
- pshkong
17 Mar 2013 15:25 #7858
by pshkong
Binding problem with DSM2 was created by pshkong
Hi All,
I have a problem in binding my Devo 10 (deviation 2.1.1) with DSM2 receivers. I tested on NanoCPX and Carbon Cub SS. I tried to use 150mW to bind as in other posts mentioned. Still, the binding sometimes works sometimes doesn't. Sometimes if I walk away and rebind, it works. But 8 out of 10 times it just can't bind properly.I just can't figure out a proper way to bind.
However, if it can bind properly, everything just work perfect. Very weird.
Anyone knows how to solve this problem? It's bugging me and I don't know how to work around this problem
Thank you very much!
- domcars0
17 Mar 2013 15:35 #7859
by domcars0
Replied by domcars0 on topic Binding problem with DSM2
Bind the Nano with DSMX protocol.. it works much much better
- pshkong
17 Mar 2013 15:37 #7860
by pshkong
Replied by pshkong on topic Binding problem with DSM2
ummm... How to do that? I can only choose DSM2 on the Model Setup page. Thanks
17 Mar 2013 15:37 - 17 Mar 2013 15:38 #7861
Replied by vlad_vy on topic Binding problem with DSM2
NanoCPX and Carbon Cub SS have DSMX receivers. From my experience, DSMX receivers not always bind with DSM2 Tx from first attempt. I need connect flight battery several times for successful bind.
Next stable Deviation version will support DSMX protocol. With DSMX protocol all these models will bind from first attempt. Or you can try to use last build with DSMX support from experimental Nightly builds.
www.deviationtx.com/repository/Deviation...ases/Nightly-Builds/
Last edit: 17 Mar 2013 15:38 by vlad_vy.
- pshkong
17 Mar 2013 15:41 #7862
by pshkong
Interesting. Let me try to nightly build first.
- pshkong
17 Mar 2013 17:21 #7863
by pshkong
Seems I corrupted the firmware after the upgrade. It keeps showing "Program Update...." after restart the radio, and nothing happen. Forzen...
What should I do?
What should I do?
- sbstnp
17 Mar 2013 17:34 #7866
by sbstnp
Try to flash the stable version, and, if it works post again, I can build another nightly for you.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Binding problem with DSM2
pshkong wrote: Seems I corrupted the firmware after the upgrade. It keeps showing "Program Update...." after restart the radio, and nothing happen. Forzen...
What should I do?
Devo 10 + 4in1
- pshkong
17 Mar 2013 17:51 #7869
by pshkong
Thanks, I reverted back to standard factory firmware, now I am at the nightly build. (Not to mention I have lost all the models... omg)
But seems the nightly build has some problem on the icon/chart area. It is all black instead of the icon, and in the mixer page, I can't see the chart that I used to see.
Besides, I tried to bind with DSMX, but no luck still...
Anyway, a newer daily build will absolutely be appreciated. Thanks in advance!
17 Mar 2013 18:22 #7870
Replied by PhracturedBlue on topic Binding problem with DSM2
I'm not aware of any problems like that with the nightly build. Make sure you have the corresponding filesystem installed (backup your models 1st)
If you can reproduce with the nightly build and the stock filesystem please post the steps you followed so I can verify and debug.
- pshkong
17 Mar 2013 18:45 #7871
by pshkong
The step I restore the nightly build is as followings:
1. Restore to factory Devo 0.6A and Devo Lib 2.0
2. Install nightly build
3. Install file system of 2.1.0
Hope this helps.
Hope this helps.
17 Mar 2013 19:14 #7872
the 2.1.0 filesystem is not compatible with the nightly build. you need to use the filesystem that goes with the nightly build
- pshkong
17 Mar 2013 20:24 #7876
by pshkong
Thanks! I will try tomorrow.
Time to create page: 0.111 seconds
- Binding problem with DSM2
