6ch FBL template
22 Mar 2013 13:17 #8000 by 944storm
6ch FBL template was created by 944storm
Would it be possible to add a 6ch FBL template. I know there is a 6ch template already, but that sends everything to cyclic mixers.
I'm starting to learn C for work so I may be able to help in the future.
Thank you for everything that's has been done!
22 Mar 2013 13:47 #8001 by Hexperience
Replied by Hexperience on topic 6ch FBL template
Its the swash type setting that effects ccpm mixing not the use of the virtual cyclic channels.
22 Mar 2013 14:23 #8002 by 944storm
Replied by 944storm on topic 6ch FBL template
OK, thank you that clears up a bunch of stuff!
22 Mar 2013 15:11 #8004 by Hexperience
No problem... I've made that mistake more than once. Every time I see the use of the cyclic1,2 and 3 I always assume it's doing ccpm mixing.
Also, did you have a look at this post... ;)
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
22 Mar 2013 16:37 #8006 by 944storm
Yes I did and that created some confusion because it was setting up everything without the cyclic channels, yet most of the model configs use the cyclic channels. Now I understand that it is the swash type that does all that mixing. I can use either way as long as I set swash plate to none.
Thank you for the info!
Time to create page: 0.227 seconds
