6ch FBL template
- 944storm
22 Mar 2013 13:17 #8000
by 944storm
6ch FBL template was created by 944storm
Would it be possible to add a 6ch FBL template. I know there is a 6ch template already, but that sends everything to cyclic mixers.
I'm starting to learn C for work so I may be able to help in the future.
Thank you for everything that's has been done!
- Hexperience
22 Mar 2013 13:47 #8001
by Hexperience
Replied by Hexperience on topic 6ch FBL template
Its the swash type setting that effects ccpm mixing not the use of the virtual cyclic channels.
- 944storm
22 Mar 2013 14:23 #8002
by 944storm
Replied by 944storm on topic 6ch FBL template
OK, thank you that clears up a bunch of stuff!
- Hexperience
22 Mar 2013 15:11 #8004
by Hexperience
No problem... I've made that mistake more than once. Every time I see the use of the cyclic1,2 and 3 I always assume it's doing ccpm mixing.
Also, did you have a look at this post...
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
- 944storm
22 Mar 2013 16:37 #8006
by 944storm
Yes I did and that created some confusion because it was setting up everything without the cyclic channels, yet most of the model configs use the cyclic channels. Now I understand that it is the swash type that does all that mixing. I can use either way as long as I set swash plate to none.
Thank you for the info!
Time to create page: 0.032 seconds
- 6ch FBL template
